Cylinder Falling from Unwinding String
The discussion centers on a homework question involving a cylinder falling from an unwinding string, with the original poster seeking assistance. Participants emphasize the importance of demonstrating effort before receiving help, referencing forum rules. Suggestions include creating a diagram to visualize the problem and identifying relevant equations to connect the variables involved. The conversation highlights the need for a structured approach to problem-solving in physics. Engaging with the material through these steps is crucial for understanding the concepts.
milanocookie
Iron cylinder with radius r has a string wound around it. As cylinder falls it unwinds string. Write an equation that relates the forces that act on the cylinder to its linear accceleration a, along with an equation that relates the torques that act on the cylinder to its angular acceleration a.
Moment of inertia of a solid cylinder is I= ½mr²
I need help with this homework question and I'm blanking out. Can anyone help me to answer this question correctly.
Break it up in steps!
A good first step is to make a drawing that shows relevant variables
A natural second step is to collect relevant equations connecting these variables
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
