Cylinder floating at interface between two liquids
20 replies · 11K views · last reply
amw2829
A less-dense liquid of density ρ1 floats on top of a more-dense liquid of density ρ2 . A uniform cylinder of length l and densityρ, with ρ1< ρ<ρ2, floats at the interface with its long axis vertical.
What fraction of the length is in the more-dense liquid?
F=ρVg
I thought I could use Vf=ρ/ρ2 but the final answer should include ρ1 and possibly l. Any help would be appreciated.
What is the magnitude of the buoyant force in general?
ehild
ehild
ρ1Vg + ρ2Vg ?
ehild said:
What is V?
ehild
∏r^2h...but I don't have r
Is V the volume of the whole rod?
ehild
ehild
From what I gathered it is a cylinder.
The buoyant force is equal to the weight of the fluid displaced. The rod is immersed partly in one fluid and the other part is in the other fluid. It can not displace its whole volume from both fluids. Assume that x length is immersed in fluid 2, and the other piece is in fluid 1. What is the total buoyant force in terms of the volume of the rod?
ehild
ehild
I'm still not sure how to calculate that with the given variables.
ehild said:
Write up Archimedes principle.
ehild
F=weight of the fluid displaced.
The rod floats, it is in equilibrium. How is F related to the weight of the rod?
ehild
Hello, I am kind of stuck on this question too (well I have an answer which I am not too sure about)
http://img27.imageshack.us/img27/3685/lratio.jpg this is a simple diagram that I drew.
Let F1 be the Buoyant force of less dense liquid and it is pointing downwards
while F2 is the buoyant force of more dense liquid is pointing upwards.
Since it is floating in middle I have assumed it to be at equilibrium, and hence F2= F1+ FG
I have used A as the area of cylinder since it is same for all regions. l1 for length of cylinder in less dense liquid and l2 for the length of cylinder in more dense liquid.
Since g appears on both sides of equation I have ignored it ( by divide the whole thing by g)
my equation ended up looking like the following;
ρ2Al2=ρ1Al1+ρAl
I have divided both sides by A leading to
ρ2l2=ρ1l1+ρl
I have divided both sides by ρ2 which leads to
l2=(ρ1l1+ρl)/ρ2
the question asks what fraction is in more dense liquid which is l2/l
(ρ1l1+ρl)/ρ2l
simplifying this leads to
(ρ1l1/ρ2l)+(ρ/ρ2)
Does this seem correct?
Regards
The hydrostatic pressure must be the same along the red line in the figure. The red line is at depth l=l1+l2 with respect to the top of block. The change of the hydrostatic pressure from zero to depth l is either ρgl or ρ1gl1+ρ2gl2. The two pressures must be equal.
You have to express l2/l in terms of the densities. For that, use that l1=l-l2.
ehild
  • Diagram of a black block floating at the interface of two liquids in a container, with a less dense yellow liquid above and a more dense grey liquid below; labels 0, l, l1, l2 and P mark depths, with a red line at the block's bottom.
ehild
Hi and thank you for your reply.
I understand what you mean, but I can't seem to solve l2/l easily, the answer I got was l2/l=(ρ-ρ1l+ρ1l2)/(ρ2l2)
I think I have made a mistake somewhere. I started by setting ρgl = ρ1gl1+ρ2gl2
divided both sides by g, took ρ1l1 to other side of equation giving me ρl-ρ1l1 = ρ2l2, then used l1=l-l2
and divided both sides by l to get l2/l.
That lead me to l2/l=(ρ-ρ1l+ρ1l2)/(ρ2l2) but I still have l2 on both sides of the equation.
Any obvious error sources that you can see?
Regards
divided both sides by g, took ρ1l1 to other side of equation giving me ρl+ρ1l1 = ρ2l2,
It is wrong from here. When you take a term to the other side of the equation, the sign will change. Substitute l-l2 for l1 first, collect the terms with l1 at one side of the equation, and the terms with l on the other side.
ehild
ehild
Hi, sorry I had - minus sign in my hand written workout, for some reason I must have put a plus sign, another one where I only put l1=l-l2 at the end lead me to l2/l=(ρ-ρ1(l-l2))/(ρ2)
Still end up with l & l2 on both sides for some reason
I will upload hand written workout in a few hours
You must collect the l2 terms on one side of the equation.
You have the equation
ρl=ρ1l1+ρ2l2.
Substitute l1=l-l2:
ρl=ρ1(l-l2)+ρ2l2
Expand:
ρl=ρ1l-ρ1l2+ρ2l2
Collect the terms with l2:
ρl=ρ1l+(ρ2-ρ1)l2
Bring ρ1l to the left-hand side.
Can you proceed?
ehild
I ended up with the following
ρ-ρ1/ρ2-ρ1 = l2/l
Does that seem ok?
ρ-ρ1/ρ2-ρ1 = l2/l
Does that seem ok?
You need to add some parentheses.
ehild
