Cylinder rotating; coeff of friction?
The problem involves a cylindrical amusement park ride where students stand against the wall as it rotates. The goal is to determine the coefficient of static friction required to prevent them from sliding down when the floor drops, given the radius and minimum speed of the ride.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss drawing free body diagrams (FBD) and writing equations of motion. There is confusion regarding the forces acting on the students, particularly the distinction between static and kinetic friction.
Some participants have provided guidance on visualizing the forces involved, suggesting different reference frames to clarify the relationships between forces. The original poster has expressed uncertainty but has received feedback that may help them progress in their understanding.
Participants are navigating the complexities of forces in a rotating system, questioning assumptions about the roles of static and kinetic friction, and the orientation of forces in their diagrams.
cugirl
At an amusement park, some physics students are on a ride where they stand against the wall in a cylindrical apparatus that begins to rotate around its center. Once they are moving fast enough the floor drops and they “stick” to the wall due to friction. The radius of the cylinder is R = 3.5 m and the minimum speed the ride must move the people at to keep them from sliding down the wall is 10 m/s. What is the coefficient of static friction between the student and wall?
Friction = mu * normal
a = V^2 / r
I am not sure how to start and which equation I need to use. The answer is supposedly 0.34, but I don't know how to get there.
Try drawing a FBD and write the equations of motion from there.
I did. I have Fn perpendicular to the person and pointing toward the center, down is mg, and up is Fk.
What do you mean by Fk?
Where are your equations of motion?
Fk = friction
I have Fk - mg = ma
Fk - mg = m*v^2 / R
Ok. Let's imagine you're in this rotating thing. The force which is pressing you to the wall is centrifugal. So the Fn has the same amount but opposite direction of centrifugal force. Now you have realized which force is Fn, you can determine the Fk. If you want to be motionless in this rotating system, you aren't allowed neither to move up or down. In other words, the resultant force looking on the y-axis should be 0.
I drew you the picture of it. You should be able to understand it now.
http://img9.imageshack.us/img9/5894/assign1.jpg
Fk suggests that you think this is kinetic friction, but the whole point is that you do not want to slide, thus static friction is involved, not kinetic.
Think about the direction of your forces. In you equation of motion, you have set two vertical forces equal to a horizontal M*a term; this cannot be correct.
Perhaps the reference frame is confusing you. Try drawing the problem rotated 90° such that the wall is horizontal, and the persons weight (ma) is acting sideways. You then have the frictional force acting in the opposite direction (opposite of motion), and the normal force from centripetal acceleration acting downwards.
How will it help to have the wall horizontal, which puts gravity horizontal and the whole world on edge, so to speak? Why not work with things as they really are? The friction force always acts opposite to (impending) motion in any case, so standing the world on its head can't improve that.
Because we typically think of gravity as acting downward. Therefore, the normal force that friction acts upon is normally downward.
In this example, gravity isn't necessarily the normal force that is resisting movement, it is the moving force; the normal force is generated by centripetal force. By drawing it sideways, you get the classic "block on a plane" type question where there is one force acting on a block in plane. Friction acts opposite with the normal force (being centripetal) acting downward.
It might not necessarily help for you, but the OP seemed to be having difficulty with the problem. Often times one just needs to look at it from a different perspective. More often than not, examining things in a different reference plane can help.
Thank you for the person (Lopina) who drew the FBD. Mine did not look like that, and I was able to solve it!
  • · Replies 21 ·
  • · Replies 16 ·
