RyanH42
- 398
- 16
RyanH42 said:I am doing research and I need to find the dark matter density of Galaxies or dust clusters (It can be any type of thing) which the distance from Earth will be ≅4000 Mpc.Here the picture
Think the radius of sphere.
Both attract each other.RyanH42 said:(This question can be also ask when BM attracts Dark matter-which I learned that's not possible- )
Where is the problem? They interact via gravity and maybe via the weak interaction, but not via anything else. The weak interaction is negligible, and the interaction via gravity is relevant at the scale of galaxies only.RyanH42 said:My question will be how can dark matter and baryonic matter can be same place without any interaction.
In general we won't expect any interaction but somehow we expect a little bit interaction which we want to see in experimentsmfb said:A tiny fraction of dark matter particles could interact via the weak interaction - that's what experiments on Earth try to see.
I'm not sure if scientists expect it or not, it's just something that we could theoretically observe, so they are checking on it. The weak interaction would cause the dark matter to decay, creating antimatter, which will produce a gamma ray photon of a very specific energy.RyanH42 said:In general we won't expect any interaction but somehow we expect a little bit interaction which we want to see in experiments
How can this decay can be possible ? If DM decays anti mattter then we have to seen it already.But we didnt observe such a thing.I am wrong ?newjerseyrunner said:The weak interaction would cause the dark matter to decay, creating antimatter, which will produce a gamma ray photon of a very specific energy.
Not sure, probably some assumed symmetries and conservation of certain quantum numbers. I'd not be the best to explain why this might be expected.RyanH42 said:How can this decay can be possible ? If DM decays anti mattter then we have to seen it already.But we didnt observe such a thing.I am wrong ?
Because dark matter is known because of it produces gravity, only things with mass produce gravity. Remember that matter is energy.RyanH42 said:Why it should be matter it can't be an energy ? A energy which never interects with matter ? Thats the reason why we can't see it ?
Well, at least gravitationally it has to.newjerseyrunner said:It's possible for dark matter to not even interact with itself.
What do you mean with "if DM decays anti matter"?RyanH42 said:If DM decays anti mattter then we have to seen it already.
Why does it have to be a banana why can't it be yellow? Matter has energy, this is not "one or another".RyanH42 said:Why it should be matter it can't be an energy ?
This is not true. Energy is the source of gravity, not matter. Mass has energy, but light and motion has energy without mass.newjerseyrunner said:only things with mass produce gravity.
The reason which I said that sentence.newjerseyrunner said:The weak interaction would cause the dark matter to decay, creating antimatter, which will produce a gamma ray photon of a very specific energy.
Maybe. We don't know.RyanH42 said:Yes DM decays to anti matter.
Maybe.RyanH42 said:I see If its even correct we cannit prove anyway.
Oh well, we know it exists and we can see its gravitational influence.RyanH42 said:We disnt even know "dark matter".
mfb said:There are four main ways dark matter can be detectable:
- it could decay with a very long lifetime (much longer than the age of the universe - after all, it is still there) to known particles like photons, electrons, muons, quarks and so on. The decay has to be mediated by the weak force or some yet unknown mechanism, as the dark matter particles do not couple to the strong and electromagnetic interaction directly. The detection would happen via telescopes and particle detectors in space.
- it could annihilate with other dark matter particles. Not a decay in the strict sense, but it gives a signature very similar to decays. The "effective lifetime" depends on the dark matter density then, but it has to be much longer than the age of the universe again.
- it could interact with matter in underground detectors. The most likely interaction is elastic - we would just see a "kick" for some particle in the detector without a visible cause.
- it could be produced in particle accelerators. The detectors wouldn't detect the dark matter directly, but it would be notable as an imbalance in the observed transverse momentum of the visible particles (simplified: we see the recoil with known particles on one side, but not the produced dark matter going to the other side)
