Debunking HUP explanation myth
  • Thread starter Thread starter loom91
    Explanation Hup
loom91
Hi,
All my chemistry textbooks (thankfully not the physics ones) and my teachers (unfortunately including the physics ones) seem bent on 'explaining' the Heisenberg Position-Momentum Uncertainty Principle using the famous thought experiment of photons striking an electron, and not one of them actually give a complete statement of HUP (they say product of uncertainties is half-h-bar without explaining that uncertainty in this context means standard deviation of observable).
I'm trying to prepare a report on why this example is not a valid derivation of HUP. I describe the reasoning below:-
In order to observe an electron, we need to 'hit it' with light. The more precisely we want to know the position, the shorter we have to make the wavelength, but the more energetic the photon becomes, disturbing the original trajectory of the electron thus increasing the uncertainty in momentum. The best books even accompany this with an illustration. This explanation is present in even books written by national government sanctioned whole workshops of authors.
The two counter-arguments I can currently find are:-
1)It is possible to measure an observable without physically disturbing the state it courtesy Bell's Theorem.
2)The explanation does not actually explain anything, since it makes no attempt to precisely define measurements or uncertainties.
More arguments/corrections/more concrete reformulations will be appreciated. I'm seeking to prepare a report which will convince a hardened old teacher and a national educational board of their errors, and it is probably a folly to assume any significant amount of prior theoretical knowledge on their part (for example I doubt how many know about entanglement). Also, this is mainly for personnel from chemistry as those from physics are at least slightly more educated in this respect.
Thanks.
Molu
Well, the fact that, in QM formalism, you can measure the position in one direction and still know the momentum exactly in an orthogonal one would seem to me to discount their explanaion. Of course, I'm not aware of an experiment that does this, but that doesn't mean there isn't one.
To me, the chemistry book's explanation is terrible because it misses the point - the inability to measure two observables whose operators do not commute is a fundamental property of quantum mechanics, and has nothing whatsoever to do with the way they are measured.
What do you mean by 'know'? You mean that the same state may be an eigenstate of the position and the momentum operators in orthogonal directions?
Any other arguments?
As I understand it, HUP points out that there is only so much information in a state. The limitation is in the state, not in the measurement of the state.
I mostly agree with jimmysnyder, but to state it more "ontologically" we can interpret the HUP as saying:
There are no actual situations in nature that warrant the assignment of sharp values to conjugate physical properties.
Note that I did not use the word "simultaneously" as for instance positions at distinct measurement times also in general do not commute.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
