Decide a matrix for a vector that goes through various morphs
  • Thread starter Thread starter Wi_N
    Matrix Vector
10 replies · 2K views
Wi_N
1. first a quarter rotation on the x-axis. 2. then being mirrored on xy-plane. 3. Then projected on the plane x+ 2y+ 3z= 0.
$$\begin{pmatrix}
1 & 0 & 0 \\
0 & cos(\theta) & -sin(\theta) \\
0& sin(\theta) & cos(\theta)
\end{pmatrix}$$
for rotating on the x-axis.
vector=(abc)
1.
$$\begin{pmatrix}
1 & 0 & 0 \\
\end{pmatrix}$$
The rotation part is correct.
2.
$$\begin{pmatrix}
1 & 0 & 0 \\
0 & 1 & 0 \\
0& 0 & 0
\end{pmatrix}$$ is wrong apparently
how do I do the mirroring?
step 3 i can do just fine.
Different authors use different setups for the XYZ setup. Do you know which one the author uses? Your matrix sends ##(x,y,z)## to ##(x, y,0)## which is not a reflection but a projection. In 2D, if you reflect across the y axis, you send ##(x,y)## to ##(-x,y)##. But the reflection you have will depend on how ##XYZ## axes are setup.
it doesn't specify just that it mirrors.
Then it seems you just have to try different options.
could you give one example? it said the rotation was in positive direction, does that help?
Can you see what happens when you reflect a generic (x,y,z) along either of the 3 planes? This should help you define the reflection matrix. Does it help?
not really.
Ok, let's see if this works:
Draw a horizontal line L . At any point of L draw a perpendicular line segment S to L so that the endpoints of S are both equidistant to L. The endpoints of S are a point and its reflection about a plane. Can you tell the relation between the two emdpoints of S ( in coordinates)?
If not, maybe @BvU can help illustrate it better?
ok so a reflecton in xy plane is given by
100
010
00-1
Yes, that is correct.
