Decimal to Binary 32 bit signed conversion
  • Thread starter Thread starter Willjeezy
    Binary Bit
6 replies · 4K views · last reply
Willjeezy
Convert -89 to 32 bit representation (2-complement for negative numbers)
my answer does not agree with calculated answers from multiple conversion sites.
to get the exponent i figured out the closest 2 exponent to 89, which is 7.
then I added the exponent to the bias, 127 + 7 = 134
therefore 134 to binary would be: (I added underscores to separate the sign/exponent and mantissa
1__________1 0 0 0 0 1 1 0___________0 1 1 0 0 1
sign___________exponent______________ mantissa
the only problem is when i check my answer on multiple sites, the answer is
1 __________1 0 0 0 0 1 0 1 ___________0 1 1 0 0 1
_____________________^---exponent they have adds up to 133 ?
what am I doing wrong?
Why are you converting to floating point form? The number you need to convert is an integer. You're making this much harder than it actually needs to be.
As Mark44 noted, you're solving the wrong problem. :wink:
But to answer the question you asked anyway, you don't want 27. You want 26, the power of 2 that's closest to 89 but less than or equal to 89. This gives you
$$89 = 1.390625 \times 2^{64}$$ which has a mantissa with the integer part equal to 1, which is what you want if you're going to convert to floating-point format.
2^64? I think you blew my mind
89 = 1.390625 * 64
vela was thinking 6 but mistakenly wrote 64.
89 = 1.390625 * 64
89 = 1.390625 * 64
Oops. Thanks for catching that.
