Help Needed: Opening & Closing Heavy Trap Door for Grandma
  • Thread starter Thread starter philbey64
The discussion centers on creating a user-friendly mechanism for a heavy trap door built for a grandmother, who struggles with its weight. Suggested solutions include leveraging torque with a long pole attached to a fulcrum, implementing a pulley system, or opting for a motorized solution that requires minimal effort, such as a button-activated mechanism. The need for a sketch of the layout was emphasized to clarify the design and constraints, particularly regarding the limited 4-inch clearance beneath the door.
  • Understanding of basic mechanical principles, such as torque and leverage.
  • Familiarity with pulley systems and their mechanical advantages.
  • Knowledge of motorized mechanisms and their applications in home automation.
  • Ability to create or interpret basic sketches or diagrams for design clarity.
  • Research "Lever and Fulcrum Mechanics" to understand how to reduce force needed to lift heavy objects.
  • Explore "Pulley Systems" and their configurations for efficient weight distribution.
  • Investigate "Motorized Door Openers" suitable for heavy trap doors, focusing on user-friendly designs.
  • Learn about "Home Automation Solutions" that can integrate with existing structures for ease of use.
This discussion is beneficial for DIY enthusiasts, home improvement professionals, and caregivers seeking practical solutions for accessibility challenges in home environments.
philbey64
I have built some decking for my grandmother, so it is easier for her to enjoy the garden. There is a bin area that has had to be on a different level, so I have put in a trap door. The thing is that she will not be able to open or close it as it too heavy. Is there any solution to this dilemma, I have thought of rams, but there is not enough distance from the underside of the door to the original path, (some 4" or 100 mm only) Has anyone got a solution on how to open and close the door with the minimum of effort, she is 71 years old and built like a matchstick!
Thanks in advance
Thanks in advance
A picture might be helpful so we can see how the system is setup.
However, I can give you some general answers. If you wish to move an object with a minimum amount of force, you could use leverage through torque. By this I mean something like a long pole which is attached to the door and a fulcrum. If the pole is long enough the force to apply by your grandmother should be really small. Another option would be a system of pulleys which would also require a very small amount of force.
If these still do not help I would suggest a motorized solution; one where she doesn't need to do more than push a button. Anyway I hope that helps, good luck.
It would help if you could give a sketch of the layout. I am confused by the apparent contradiction between a "Bin" beneath the floor and " only a 4" clearance to the ground below".
9K
  • · Replies 25 ·
