Can Any Linear Operator Be Decomposed into Hermitian Components?
Any linear operator can be expressed as a sum of Hermitian components, specifically in the form \hat{O} = \hat{O}' + i\hat{O}''. The operators \hat{O}' and \hat{O}'' can be derived from the relationships involving the adjoint of the operator, leading to the equations \hat{O}' = \frac{1}{2}(\hat{O} + \hat{O}^\dagger) and \hat{O}'' = \frac{1}{2i}(\hat{O} - \hat{O}^\dagger). The discussion emphasizes the importance of verifying that these components maintain the properties of Hermitian operators. Participants suggest experimenting with arbitrary vectors and eigenvalue equations to explore the decomposition further. The approach involves a combination of intuition and careful verification to ensure the solution meets the original problem's requirements.
dingo_d
Show that any linear operator \hat{O} can be decomposed as \hat{O}=\hat{O}'+i\hat{O}'', where \hat{O}' and \hat{O}'' are Hermitian operators.
Operator is Hermitian if:
T=T^{\dagger}
I don't know where to start :\ Should I try to see for some arbitrary vector |\psi\rangle, that I can write it in some basis, and see what it would do to write eigenvalue equation with those operators?
Play with \hat{O}^\dagger+\hat{O} and i(\hat{O}^\dagger-\hat{O}).
Hmmm.
So \hat{O}^{\dagger}+\hat{O}=\hat{O}'^{\dagger}-i\hat{O}''^{\dagger}+\hat{O}'+i\hat{O}'' and since those with ' and '' are hermitian it follows:
\hat{O}^{\dagger}+\hat{O}=\hat{O}'-i\hat{O}''+\hat{O}'+i\hat{O}''=2\hat{O}'
Am I on the right track?
Not too bad ...
XD Too bad? XD
For the i(\hat{O}^\dagger-\hat{O}) part I got 2\hat{O}''
So I should somehow prove linear superposition or?
Well, so what is your guess for O' and O''? Guess what they should be, then check carefully if your guess has all the required properties.
This is how we often solve problems: we play, we guess, and the we check carefully, in all detail, if our guess really constitutes a solution of the original problem. The way towards a solution does not have to be logical. What needs to be logical is the verification.
  • · Replies 0 ·
