Defining Probability: Beyond Relative Frequency
  • Thread starter Thread starter RobtO
    Probability
The discussion centers on the distinction between probability and relative frequency, emphasizing that probabilities are not strictly defined by relative frequencies. The frequentist interpretation views probability as based on observed frequencies, while the Bayesian interpretation considers probabilities as degrees of belief. Both interpretations fit within Kolmogorov's axiomatic definition of probability, which treats probability as a measure. The conversation highlights that probabilities represent predictions, whereas relative frequencies reflect actual measurements, and that conditional probabilities are distinct from relative frequencies. The authors argue for the importance of recognizing this distinction in theoretical and experimental contexts.
RobtO
I am reading "The Quantum Theory of Measurement," by Busch, Lahti, and Mittelstaedt, and I came across this statement (p. 44, 1996 ed.):
"The difficulties encountered in giving a precise formulation of this idea are due to the facts that relative frequencies are not probabilities, and probabilities need not be relative frequencies."
Again, on p. 47, they mention that "... the concept of probability cannot be reduced to that of relative frequency."
Now, I was taught at my mother's knee (well, my physics professor's) that probability was defined in terms of relative frequency. Can anyone help me understand what probability means, if not relative frequency, and under what conditions "probabilities need not be relative frequencies"?
If relative frequencies can be predicted from theory, then these would be probabilities. However experimental data can give only estimates. A simple example - coin flipping. Theoretically (assuming a good coin) heads or tails each have probability 1/2. However if you flip a coin twice, you will get one head and one tail only half the time. A large number of flips give you approximately 50% heads and 50% tails, but the chances of getting exactly those results is small.
That's the frequentist interpretation of probability, which is a common one (particularly amongst physicists), but by now means the only widely-accepted definition. The other big one is the Bayesian interpretation, which views probabilities as "degrees of belief" (or some other subjective entity).
In terms of the gory details of how this stuff is really defined, axiomatically, it does not matter which interpretation you employ. The formalism isn't sensitive to it.
There are useful aspects of both the frequentist and Bayesian interpretations. I go by the duck probability model: If it looks like a duck and quacks like a duck ...
... and in this case the duck is embodied in measure theory. Suppose (\Omega,{\mathcal F}, \nu) is a measure space -- i.e., \mathcal F is a σ-algebra on the set \Omega and \nu is a measure function on \mathcal F. If \nu(\Omega)=1 then (\Omega,{\mathcal F}, \nu) is a probability space. In this case, the set \Omega is typically called the sample space and the measure function \nu is typically replaced by P to denote probability.
Both the frequentist and Bayesian concepts of probability fall within this axiomatic definition of probability, which was developed by Kolmogorov.
A couple of good examples of where the Bayesian view is extremely powerful: Bayesian estimation (e.g., Kalman filters) and Bayesian inferencing (e.g., causal networks). A tutorial on Bayesian estimation and Kalman filters: http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.40.7026. A course on Bayesian inferencing: http://ite.gmu.edu/~klaskey/SYST664/SYST664.html .
Probability is a measure. Think in terms of Kolmgorov's axiomatic definition. Conditional probability is a different measure than relative frequency type probability.
Thanks for the responses. It seems that what folks are saying is: probabilities are what you predict, but relative frequencies are what you actually measure. If this is the case, I'm not sure why the authors make such a big deal about the distinction. In physics, of course, we constantly have to deal with the distinction between predictions (theory) and experiment.
They actually define the relative frequency as the limit N -> infinity of the measured values, then prove as a theorem that the relative frequency is equal to the probability under appropriate conditions. I'm still not sure why you would need to do this, if it's just a matter of the interpretation you put on probability.
But anyway, would you all agree that there's no barrier to putting a frequency interpretation on a given set of probabilities?
But doesn't the formula
P(A|B) = {P(A \cap B) \over P(B)}<br /> <br />
reduce the conditional probability to relative frequencies?
No. You misinterpreted what I and others wrote. We used the term mathematical definition of "measure", which is not at all the same as an experimental measurement. The mathematical concept of measure is essentially a generalization of the concept of length. You can google "measure theory" to get a taste of the concept.
A primer on measure theory: http://www.math.uconn.edu/~bass/meas.pdf .
How it relates to probability: http://www.math.uconn.edu/~bass/prob.pdf .
Not really. P(A|B) is another measure, this does not require concept of frequency.
http://en.wikipedia.org/wiki/Probability_space
http://www.probabilityandfinance.com/articles/06.pdf
I will give an example. Events with very very small (but non zero) probabilities does not occur in practice.
Let us think that a person is trying to insert an envelop into a letter box from a distance of 10meters by throwing the envelop.
The slit of the box is just 1mm wider and longer than the thickness and width respectively of the envelop. Theoritically his chance [probability measure(by 'measure', I loosely mean 'a basis for comparison')] of success is not zero. But practically, however large number of trials he performs, his relative frequency of success will be exactly zero.
  • · Replies 69 ·
  • · Replies 30 ·
10K
