What is the Definition of Derivative and How is it Proved?
The discussion focuses on the definition and proof of the derivative in calculus, specifically using the limit definition. The derivative at a point \( f'(a) \) is established as \( \lim_{h \to 0} \frac{f(a+h) - f(a)}{h} \). Participants emphasize the importance of adhering to the \( \epsilon-\delta \) definition of limits rather than mixing it with sequential definitions. The conversation also highlights common mistakes in proofs and the necessity for clarity in mathematical arguments.
  • Understanding of limits and continuity in calculus
  • Familiarity with the \( \epsilon-\delta \) definition of limits
  • Basic knowledge of derivatives and their properties
  • Ability to manipulate mathematical expressions and proofs
  • Study the \( \epsilon-\delta \) definition of limits in detail
  • Learn about the properties of derivatives and their applications
  • Explore common pitfalls in calculus proofs and how to avoid them
  • Practice proving the existence of limits using different approaches
Students of calculus, mathematics educators, and anyone seeking to deepen their understanding of derivatives and limit proofs.
fishturtle1
Suppose ##f## is differentiable at ##a##. Prove ##\lim_{h\rightarrow 0} \frac{f(a+h) - f(a)}{h} = f'(a)##
##f## is differentiable at ##a## means ##\lim_{x\rightarrow a} \frac{f(x) - f(a)}{x-a}## exists and is finite.
##\lim_{x\rightarrow a} g(x) = L## means for any sequence ##(x_n)## that converges to ##a##, we have ##\lim_{n\rightarrow\infty} g(x_n) = L##.
Alternatively, ##\lim_{x\rightarrow a} g(x) = L## means for all ##\varepsilon > 0## there exists ##\delta = \delta(\varepsilon) > 0## such that ##\vert x - a \vert < \delta## implies ##\vert g(x) - L \vert < \varepsilon##.
Proof: By definition of derivative,
$$f'(a) = \lim_{x\rightarrow a}\frac{f(x) - f(a)}{x - a}$$
exists and is finite. Let ##(x_n)## be any sequence that converges to ##a##. By definition of limit, we have $$\lim_{x_n\rightarrow a} \frac{f(x_n) - f(a)}{x_n - a} = f'(a)$$. By definition of convergence, for all ##\varepsilon > 0## there exists ##N = N(\varepsilon) > 0## such that ##n > N## implies ##\vert x_n - a \vert < \varepsilon##, i.e. ##\lim_{n\rightarrow\infty} (x_n - a) = 0##. Let ##h = x_n - a##? Then
$$\lim_{h \rightarrow 0} \frac{f(a + h) - f(a)}{h} = f'(a)$$. []
I'm pretty sure this is wrong because I said ##h = x_n - a##, but ##h## is a constant and ##x_n - a## is a sequence.. also I don't think I can substitute ##h## under the limit like I did, but I'm not sure.
You are mixing two characterisations of limits. I think it is better to work with the ordinary ##\epsilon-\delta##-definition of limit in this case, and not with the sequential characterisation. But the right idea can definitely be observed in your proof, although as written it contains multiple mistakes. Here is how I would write it:
Let ##\epsilon > 0##. Since ##f'(a)## exists, there is ##\delta > 0## such that
$$\forall x \in\mathbb{R}: \left(0 < |x-a| < \delta \implies \left|\frac{f(x)-f(a)}{x-a}-f'(a)\right| < \epsilon\right) \quad (*)$$
Let ##h \in \mathbb{R}## with ##0< |h|= |h-0| <\delta##. Then
$$\left|\frac{f(a+h)-f(a)}{h}-f'(a)\right| < \epsilon$$
since ##|(a+h)-a| = |h| < \delta## (i.e. we apply ##(*)## with ##x= a+h##).
Thus, we have proven that for each ##\epsilon >0##, there is ##\delta > 0## such that for all ##h \in \mathbb{R}## with ##0 < |h| < \delta##, we have ##\left|\frac{f(a+h)-f(a)}{h}-f'(a)\right|< \epsilon##.
This is precisely the definition of ##\lim_{h \to 0} \frac{f(a+h)-f(a)}{h} = f'(a)## and we are done!
____________
Similar exercise, to see if you understood this one:
Show that for a function ##f: \mathbb{R} \to \mathbb{R}## and a real number ##x \in \mathbb{R}##:
$$\lim_{h \to 0} f(x+h) \mathrm{\ exists \ and \ equals \ } f(x) \iff \lim_{y \to x} f(y) \mathrm{\ exists \ and \ equals \ } f(x)$$
____________
Thank you so much, this clears up my confusion.
Edit: just read the edit, will try.
Show that for a function ##f : \mathbb{R} \rightarrow \mathbb{R}## and a real number ##x \in \mathbb{R}##:
##\lim_{h\rightarrow 0}f(x+h)## exists and equals ##f(x) \iff \lim_{y\rightarrow x}f(y)## exists and equals ##f(x)##.
Proof: ##(\Rightarrow)## Let ##\varepsilon > 0##. Then there is ##\delta = \delta(\varepsilon) > 0## such that $$\vert h - 0 \vert < \delta$$ implies $$\vert f(x+h) - f(x) \vert < \varepsilon$$ Then, for all ##y \in \mathbb{R}##, if $$\vert y - x \vert = \vert h \vert < \delta$$ we have $$\vert f(x + (y - x)) - f(x) \vert = \vert f(y) - f(x) \vert < \varepsilon$$ This shows that ##\lim_{y \rightarrow x} f(y) = f(x)##.
##(\Leftarrow)## Let ##\varepsilon > 0##. Then there is ##\delta = \delta(\varepsilon) > 0## such that for any ##y \in \mathbb{R}##, if $$\vert y - x \vert < \delta$$ then $$\vert f(y) - f(x) \vert < \varepsilon$$
So, for any ##h \in \mathbb{R}##, if
$$\vert h - 0 \vert = \vert y - x \vert < \delta$$
then
$$\vert f(x + h) - f(x) \vert < \varepsilon$$
This shows ##\lim_{h\rightarrow 0} f(x + h) = f(x)##. []
then
Correct! But I would change the part"##|y-x|=|h|<\delta##" simply to "##|y-x|<\delta##" because you didn't define ##h## anywhere. You can just add a line with "we apply the previous inequality with ##h=y-x##" to make it clear what you are doing. But this is just a small nitpick. Everybody will understand what you are doing and that'the most important thing.
OK, I see what you mean. Thank you again for your help.
:oldconfused: Is it just me, am I the only one missing the point of all this?:olduhh:
The student states what differentiable means, states the definition of f', to prove the required formula is a trivial substitution in the definition formula, the two formulae say the same thing really.
What am I missin?
What am I missin?
Yes, the two formulae say the same thing formally. But one must prove formally that one is allowed to make the substitution. This is the whole point of the exercise.
  • · Replies 20 ·
