Is Every Statement Correct in Defining an Onto Function?
  • Context: MHB
  • Thread starter Thread starter lemonthree
    Definition Function
A function f:A→B is defined as onto if its range equals its codomain, denoted as f(A) = B. The correct statements that describe an onto function include: "In the arrow diagram representing f, every point in B has an arrow pointing at it," "∀y∈B ∃x∈A such that f(x)=y," "Every element of B is the image of some element in A," and "Every element of B has at least one preimage." The incorrect statements include those that do not ensure every element in B is covered by the mapping from A.
  • Understanding of function notation and terminology (e.g., domain, codomain, range).
  • Familiarity with the concept of onto functions in mathematics.
  • Knowledge of set theory and mappings between sets.
  • Basic understanding of arrow diagrams representing functions.
  • Study the properties of onto functions in more depth.
  • Learn about one-to-one (injective) functions and their differences from onto functions.
  • Explore the concept of bijective functions, which are both onto and one-to-one.
  • Review examples of functions and their corresponding arrow diagrams to visualize mappings.
Mathematicians, educators, and students studying advanced algebra or calculus, particularly those focusing on function properties and set theory.
lemonthree
Which of the following statements is equivalent to saying that a function f:A→B is onto? There are 8 options, select all that are correct.
xf(A)=B
xIn the arrow diagram representing f, every point in B has an arrow pointing at it.
x∀y∈B ∃x∈A such that f(x)=y
xf−1(B)=A
xEvery element of B is the image of some element in A
∀x∈A ∃y∈B such that f(x)=y
Every element of A has a corresponding image in B
xEvery element of B has at least one preimage.
I have marked with an "x" those that I believe are correct. However, I am not entirely sure.
Let me explain my selection.
1. f(A) = B is true, because B is the whole set B where A is mapped to B, so it is onto? (range = codomain)
2. Valid, because it shows that the range = codomain.
3. Similar to point 2, it shows that range = codomain.
4. In this case, it is similar to 1? It seems to say that the whole set of B can be mapped back to A.
5. Yes, every element of B (codomain) is the image of some x in A.
6. Not true for onto function, because it does not cover all of B, only some in B.
7. Not true for onto function, because it does not talk about covering all options in B.
8. True because every element of B is covered.
Please point out if I have made any mistakes in my explanation, thank you!
The definition of "function from A to B", whether "onto" or not, requires that
"∀x∈A ∃y∈B such that f(x)=y".
Indeed, I agree with you. However, I did not select it because the question asks "Which of the following statements is equivalent to saying that a function f:A→B is onto?". So I'm guessing that a normal function won't make the cut?
Regarding point 4, $f^{-1}(B) = \{x \in A \mid f(x)\in B\}$. Since B is the co-domain, this is true for any function $f:A\to B$.
f(A)=B
f−1(B)=A
Thank you very much @castor28 for pointing that out. Following that logic, I should also not select f(A)=B because B is the codomain (and it doesn't mention that the range = codomain?)
So I guess there are only 4 sentences that describe an onto function here
Point 1 was correct.
$f(A)$ is the range, $B$ is the co-domain. $f$ is onto if the range equals the co-domain, i.e., if $f(A) = B$.
I see, thank you for your explanation.
