What Determines the Degree of the Gauss Map in Differential Geometry?
The discussion focuses on the properties of the Gauss map defined for a surface ##M^{2} \subset \mathbb{R}^{3}##, specifically how the equation $$n^{*}\text{vol}^{2}_{S}=K\text{vol}^{2}_{M}$$ indicates that the Gauss map is a local diffeomorphism at points where the Gauss curvature ##K(p) \neq 0##. It establishes that if the surface is positively oriented, the image under the Gauss map will also be positively oriented on the unit sphere ##S^2## if ##K > 0##. The discussion also touches on the evaluation of the Brouwer degree of the Gauss normal map and its implications for vector fields extending to non-vanishing fields on manifolds.
  • Understanding of differential geometry concepts, particularly Gauss curvature.
  • Familiarity with the Gauss map and its mathematical formulation.
  • Knowledge of the Inverse Function Theorem and its applications.
  • Basic principles of Brouwer degree in topology.
  • Study the properties of the Gauss map in differential geometry.
  • Learn about the implications of the Inverse Function Theorem in the context of manifolds.
  • Research the Brouwer degree and its applications in topology.
  • Explore Stokes' Theorem and its relevance to vector fields on manifolds.
Mathematicians, differential geometers, and students studying topology who are interested in the properties of Gauss maps and their applications in understanding manifold behavior.
spaghetti3451
If ##M^{2} \subset \mathbb{R}^{3}## is a surface with given normal field, we define the Gauss (normal) map
$$n:M^{2} \rightarrow \text{unit sphere}\ S^{2}$$
by
$$n(p) = \textbf{N}(p), \qquad \text{the unit normal to $M$ at $p$}.$$
It can be shown that
$$n^{*}\text{vol}^{2}_{S}=K\text{vol}^{2}_{M},$$
where ##\text{vol}^{2}_{S}## is the volume form in ##S^{2}##, ##\text{vol}^{2}_{M}## is the volume form of ##M^{2}## and ##K## is the Gauss curvature.
This means that
1. the Gauss map is a local diffeomorphism in the neighbourhood ##U## of any ##p \in M^{2}## at which ##K(p)\neq 0## (alternatively, ##u \in M## is a regular point for the Gauss map provided ##K(u)\neq 0##)
2. if ##U## is positively oriented then ##n(U)## will be positively oriented on ##S^2## iff ##K>0##.
Let ##y \in V## be a regular value of ##\phi: M^{n} \rightarrow V^{n}##; that is, ##\phi_{*}## at ##\phi^{-1}(y)## is onto. For each ##x \in \phi^{-1}(y)##, ##\phi_{*}:M_{x}\rightarrow V_{y}## is also ##1:1##; that is, ##\phi_{*}## is an isomorphism. Put
$$\text{sign}\ \phi(x) := \pm 1$$
where the ##+## sign is used iff ##\phi_{*}:M_{x}\rightarrow V_{y}## is orientation-preserving. Then
$$\text{deg}(\phi)=\sum_{x \in \phi^{-1}(y)} \text{sign}\ \phi(x)$$
1. Why does ##n^{*}\text{vol}^{2}_{S}=K\text{vol}^{2}_{M}## mean that the Gauss map is a local diffeomorphism in the neighbourhood ##U## of any ##p \in M^{2}## at which ##K(p)\neq 0##?
2. Why does ##n^{*}\text{vol}^{2}_{S}=K\text{vol}^{2}_{M}## mean that ##u \in M## is a regular point for the Gauss map provided ##K(u)\neq 0##?
3. Why does ##n^{*}\text{vol}^{2}_{S}=K\text{vol}^{2}_{M}## mean that, if ##U## is positively oriented then ##n(U)## will be positively oriented on ##S^2## iff ##K>0##?
4. How can we use these three facts to evaluate the Brouwer degree of the Gauss normal map?
The Gauss curvature is the determinant of the Gauss map. This and the Inverse Function Theorem is all you need for 1-3.
The Brouwer degree sums the number of points in the inverse image of a regular value with orientation taken into account. When the Gauss curvature is positive the orientation sign is +1. When the Gauss curvature is negative the sign is -1
Assume that the surface is compact without boundary. Then convince yourself that:
The pull back of any 2-form that integrates to 1 over the 2-sphere integrates over the surface to the Brouwer degree of the Gauss map.
In particular the pull back of 1/4π times the volume form of the unit sphere integrates to the Brouwer degree.
The the Brouwer degree is independent of the regular value.
Thanks!
Can you help me with another thing?
Let's say that you have a map from ##M^n## to ##S^n## such that the vector field ##\bf v## on ##M^n## can be extended to be a non-vanishing vector field on all of the interior region ##U^{n+1}## of ##M^n##.
I was wondering why this means that the Brouwer degree of the map from ##M^n## to ##S^n## is ##0##
Any ideas?
failexam said:
Thanks!
Any ideas?
Not sure what you are asking. Are you saying that the manifold is the boundary of a 1 higher dimensional manifold?
if lavinia's guess is correct, and i believe it is, then you should be able to use stokes' theorem.
Also try the Implicit function Theorem.
  • · Replies 20 ·
  • · Replies 36 ·
