The Degree of the Zero Polynomial: Why is it Defined as -∞?
  • Context: Graduate
  • Thread starter Thread starter marellasunny
    Degree Polynomial Zero
The degree of the zero polynomial is defined as -∞ to maintain consistency in polynomial degree operations, specifically the formula deg(P) + deg(Q) = deg(PQ). This definition ensures that when multiplying any polynomial P by the zero polynomial, the degree remains valid, as deg(P) + deg(0) must equal deg(0). While some sources may state that the zero polynomial has no degree or assign it a degree of -1, the -∞ designation is the most mathematically consistent choice. This definition aligns with the properties of the extended real numbers.
  • Understanding of polynomial degrees and operations
  • Familiarity with the concept of the zero polynomial
  • Knowledge of the extended real numbers
  • Basic algebraic principles related to polynomials
  • Research the properties of the zero polynomial in various mathematical contexts
  • Explore the implications of defining polynomial degrees in different ways
  • Study the extended real number system and its applications in mathematics
  • Examine polynomial multiplication and its effects on degree calculations
Mathematicians, educators, and students seeking a deeper understanding of polynomial theory and the rationale behind the definition of the zero polynomial's degree.
marellasunny
I understand that mathematicians have had to define the number '0' also as a polynomial because it acts as the additive identity for the additive group of poly's.What I do not understand is why they define the degree of the zero polynomial as [ tex ]-\infty[ /tex ].
An explanation on planetMath wasn't that helpful,at the end they point-out to refer to the extended real numbers(don't they mean 'projectively extended real numbers??)
Mathematics news on Phys.org
Well, I guess it's similar to how one sometimes regards zero as both a real and an imaginary number because you can write 0 = 0 + i0. Similarly, you can write
0 = 0 + 0x + 0x2 + 0x3 + ...
i.e., you can write '0' as an infinite degree polynomial with all coefficients zero.
(There may be a more rigorous reason, but that's an intuitive one).
Thanks!Could you explain what extended real numbers have got to do with this?
But,polynomials always have non-negative degrees.
deg[P(x)]=+n
Why would mathematicians define a polynomial with a negative degree?
Huh, I'm looking at a precalculus textbook (Larson, 8th Ed.), and it states that the zero polynomial has no degree. Is that wrong? (Note that no degree ≠ zero degree -- a polynomial that consists of a single non-zero number has a degree of zero.)
The choice is pretty arbitrary. Sometimes it defined as having no degree, sometimes it's -1, sometimes it's -\infty.
A handy formula for polynomials is
deg(P)+deg(Q)=deg(PQ)
If we want this formula to hold for the zero polynomial, then we see (by taking Q=0) that
deg(P)+deg(0)=deg(0)
must hold for all P. This is only satisfied with deg(0)=-\infty. This is the reason why they defined it this way. But again, it's pretty arbitrary.
I see now. Thank you.
Awesome!Thanks a ton.
  • · Replies 0 ·
  • · Replies 0 ·
