Can Dehn Twists Be Applied to Non-Orientable Manifolds Like the Moebius Strip?
  • Context: Graduate
  • Thread starter Thread starter tom.stoer
The discussion centers on the application of Dehn twists to non-orientable manifolds, specifically the Moebius strip. It is established that while Dehn twists can be defined for tori, their application to non-orientable surfaces presents challenges due to the inability to define tubular neighborhoods at every point. The conversation suggests that the Moebius strip can be viewed as a ℤ₂ bundle over a circle, allowing for classification of twists through knot theory. Ultimately, it is concluded that twists of the Moebius strip with angles of π, , and are diffeomorphic and thus do not yield new topological information.
  • Understanding of Dehn twists in topology
  • Familiarity with non-orientable manifolds
  • Basic knowledge of knot theory
  • Concept of tubular neighborhoods in differential geometry
  • Research the properties of non-orientable manifolds in topology
  • Study the implications of Dehn twists in higher-dimensional manifolds
  • Explore knot theory and its applications to classifying twists
  • Investigate the concept of ℤ₂ bundles and their significance in topology
This discussion is beneficial for mathematicians, topologists, and students studying differential geometry, particularly those interested in the properties of non-orientable surfaces and their applications in knot theory.
tom.stoer
I am familiar with the so-called Dehn twists applied to tori (from a "physical" perspective like in string theory).
My question: is it possible to generalize the Dehn twist or a similar concept to non-compact and/or non-orientable manifolds?
What I have in mind is the Moebius strip: it is constructed like a "twisted" torus: cut a cylindrical strip, twist it by π, 2π, 3π, ... and glue it together again; for π, 3π, ... this does not preserve the topology of the strip; for 2π, ... it does, at least locally (what is not preserved is the topology of the embedding on 3-space).
Second question: is there a classification based on the generalized Dehn twist which allows one to distinguish between the π, 3π, ... cases which are identical locally?
I think that the issue is that in a non-orientable manifold you cannot define tubular neighborhoods ( the ones you use to define a Dehn twist) at every point. Instead of tubular neighborhoods, you will have a sort of mobius-strip-like object. See, e.g., http://en.wikipedia.org/wiki/2-sided
I think orientability of a manifold is equivalent to every curve defined on the manifold being two-sided, as in the Wiki definition. Maybe there is some other type of construction beyond this, but not that I know of.
EDIT: I think I may have misunderstood --or misunderestimated--your question.I think you know one can't define a tubular 'hood at every point of a non-orientable surface,and you want to know if there is a variant of it that would allow you to define a version of a Dehn twists for a non-orientable surface. Sorry if I misunderstood.
Bacle2 said:
EDIT: I think I may have misunderstood --or misunderestimated--your question.I think you know one can't define a tubular 'hood at every point of a non-orientable surface ...
Yes, I know that.
It was my intention to find a variant which works for non-orientable manifolds.
It seems like you want to embed the Mobius strip inside a solid torus, such that Dehn twists of the torus correspond to extra ##2\pi## rotations of the Mobius strip. On the surface of the solid torus, Dehn twists are diffeomorphisms. Does this fact extend to the solid interior? Intuitively, I would think so. If that is the case, then this will give you no new information about the Mobius band; the bands with ##\pi, 3\pi, 5\pi \ldots## twists are all diffeomorphic (and hence homeomorphic).
What you can do instead is think of the Mobius strip as defined by its edge(s). Basically, as a ##\mathbb{Z}_2## bundle over a circle. Then you can classify the various twists with knot theory. But this does depend on the embedding in 3 dimensions.
Incidentally, even a torus cannot "see", intrinsically, that it is Dehn twisted. That's kind of the point. If you quotient the plane by a lattice, any transformation that leaves the lattice invariant will necessarily leave the quotient invariant. So tori that differ by a Dehn twist are actually identical.
  • · Replies 43 ·
10K
  • Poll Poll
21K
  • Poll Poll
