Density, Volume and Slicing Problem
2 replies · 4K views · last reply
Eonfluxx
A compressible liquid has density which varies with height. AT the level of h meters above the bottom, the density is 40(5 - h) kg/m3
a) The liquid is put in the containers below. The cross sections of the container are isosceles triangles. It has straight sides and looks like a triangular prism. How many kg will it hold when placed as shown on the left, resting on one triangular side?​
Diagram of a triangular prism standing on one triangular face, with the top horizontal edge labelled 2 m and the vertical height labelled 4 m, and a right-angle marker at the apex of the triangle.
^There is a picture of the object.
Mass = Volume times Density
My theory is that since M = V*D, and you're given the density, should I slice and solve for volume, then evaluate the integral of volume and the given integral for density then multiply the results to get the mass?
[tex]\int^{4}_{0}2.5 dh[/tex] and [tex]40\int^{4}_{0}5-h dh[/tex]
I got to the first integral by taking the volume of the first slice (triangular prism):
[tex]\sum\frac{1}{2}b*l*\Delta h[/tex] [tex]\rightarrow[/tex] [tex]\sum\frac{1}{2}2*2.5\Delta h[/tex] [tex]\rightarrow[/tex] lim as [tex]\Delta h[/tex] [tex]\rightharpoonup[/tex][tex]\int^{4}_{0}2.5 dh[/tex]
To find the mass, according to the equation M=VD, should I solve both integrals , one being V and one being D, then multiply?
Ah... It's starting to make more sense now, thanks. So since density is varying with the height we make it all one integral rather than separate ones. Part B is the same question except with the 4m on the ground on its point with the rectangle side up. I figured once I'd managed A, B would be simple. Thanks!
