Density, Volume and Slicing Problem
  • Thread starter Thread starter Eonfluxx
    Density Volume
The discussion focuses on calculating the mass of a compressible liquid with a height-dependent density of 40(5 - h) kg/m³, contained within a triangular prism. The solution involves using the mass formula M = V * D, where the volume is derived from integrating the cross-sectional area of the triangular prism and the density is integrated over the height. The final mass calculated is 1099.68 kg, achieved through a triple integral setup for part B of the problem.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with the concept of mass as a function of volume and density.
  • Knowledge of geometric properties of isosceles triangles and triangular prisms.
  • Experience with setting up and evaluating multiple integrals.
  • Study the application of triple integrals in calculating volumes and masses of irregular shapes.
  • Learn about varying density functions and their implications in fluid mechanics.
  • Explore the use of Wolfram Alpha for solving complex integrals and visualizing results.
  • Review the properties of isosceles triangles in relation to volume calculations in physics.
Students in calculus and physics courses, particularly those tackling problems involving variable density fluids and integration techniques.
Eonfluxx
A compressible liquid has density which varies with height. AT the level of h meters above the bottom, the density is 40(5 - h) kg/m3
a) The liquid is put in the containers below. The cross sections of the container are isosceles triangles. It has straight sides and looks like a triangular prism. How many kg will it hold when placed as shown on the left, resting on one triangular side?​
^There is a picture of the object.
Mass = Volume times Density
My theory is that since M = V*D, and you're given the density, should I slice and solve for volume, then evaluate the integral of volume and the given integral for density then multiply the results to get the mass?
[tex]\int^{4}_{0}2.5 dh[/tex] and [tex]40\int^{4}_{0}5-h dh[/tex]
I got to the first integral by taking the volume of the first slice (triangular prism):
[tex]\sum\frac{1}{2}b*l*\Delta h[/tex] [tex]\rightarrow[/tex] [tex]\sum\frac{1}{2}2*2.5\Delta h[/tex] [tex]\rightarrow[/tex] lim as [tex]\Delta h[/tex] [tex]\rightharpoonup[/tex][tex]\int^{4}_{0}2.5 dh[/tex]
To find the mass, according to the equation M=VD, should I solve both integrals , one being V and one being D, then multiply?
Ah... It's starting to make more sense now, thanks. So since density is varying with the height we make it all one integral rather than separate ones. Part B is the same question except with the 4m on the ground on its point with the rectangle side up. I figured once I'd managed A, B would be simple. Thanks!
  • · Replies 60 ·
