Derivation of Acceleration from Velocity with Partial derivatives
To derive acceleration from velocity using partial derivatives, it's essential to view velocity as a function of time and spatial variables: V(t, x, y, z). The acceleration is expressed as the total derivative of velocity, which incorporates both the time derivative and the spatial derivatives through the chain rule. The formula for acceleration combines these derivatives, resulting in the equation that includes the partial derivatives of velocity with respect to time and space. Understanding the chain rule for partial derivatives is crucial for grasping this concept. This mathematical approach is fundamental in fluid mechanics for analyzing motion.
fluidmech
I'm taking a fluid mechanics class and I'm having an issue with acceleration and background knowledge. I know this is ridiculous, but I was hoping someone might be able to explain it for me.
I definitely understand:
##a=\frac{d\vec{V}}{dt}##
And I know that u, v, and w are components of the velocity, ##\vec{V}=<u,v,w>##
But how do I use the chain rule of differentiation to get to:
##\vec{a}=\frac{d\vec{V}}{dt}=\frac{\partial \vec{V}}{\partial t} +\frac{\partial \vec{V}}{\partial x}\frac{dx}{dt} +\frac{\partial \vec{V}}{\partial y}\frac{dy}{dt} +\frac{\partial \vec{V}}{\partial z}\frac{dz}{dt}##
Thanks in advance!
- Matt
Thanks in advance!
- Matt
You want to think of V as a function of four variables V(t,x,y,z).
I see, I'm still a bit hazy on the mathematics of the partials, would you mind elaborating on that?
Look up the chain rule for partial derivatives. E.g. http://mathworld.wolfram.com/ChainRule.html
That helped me tremendously. Now I understand it, thank you!
  • · Replies 29 ·
