Derivation of mazwell boltzman statistics.
  • Context: Graduate
  • Thread starter Thread starter ajayguhan
    Derivation Statistics
The discussion centers on the derivation of Maxwell-Boltzmann statistics, focusing on the calculation of the number of ways to achieve a given microstate, represented by the equation Ω = N! / (n_0! * n_1! * ... * n_r!). The application of Stirling's approximation simplifies the logarithm of Ω, leading to the maximization of Ω under constraints of total particle number and total energy. The use of Lagrange multipliers is highlighted as a method to treat the parameters independently while adhering to these constraints, ultimately resulting in the equations ln(n_i) - a - b*e_i = 0 for each energy level.
  • Understanding of statistical mechanics and thermodynamics
  • Familiarity with Lagrange multipliers and optimization techniques
  • Knowledge of Stirling's approximation in mathematical statistics
  • Basic concepts of microstates and macrostates in statistical physics
  • Study the application of Lagrange multipliers in constrained optimization problems
  • Explore Stirling's approximation and its implications in statistical mechanics
  • Learn about the derivation and applications of the canonical ensemble in thermodynamics
  • Investigate the differences between Maxwell-Boltzmann, Bose-Einstein, and Fermi-Dirac statistics
Physicists, statisticians, and students of thermodynamics who are interested in the statistical foundations of particle distributions and the mathematical techniques used in statistical mechanics.
ajayguhan
Let number of energy levels be e(subscribe 0), e(subscribe 1)...e(subscribe r)
N be the total number of particles and n(subscribe i) be the number of particle in with energy level where i =0,1,2,...r
Let Ω be the number of ways attaining a given microstate
Ω=N!/[ n(subscribe 0)!*n(subscribe 1)!*...n(subscribe r)! ]
For the most probable state Ω should be maximum i.e.,
dΩ/d(n subscribe i) =0
lnΩ=ln[N!]-ln [summation of n(subscribe i)! ] where i=0,1,...r.
Applying stirlings approximation
lnΩ={ N*ln[N]-N }- [summation of n(subscribe i)*ln [n(subscribe i)]-n(subscribe i)
Taking derivative with respective n(subscribe i)
Let n(subscribe i)=n(i)
(1/Ω)*dΩ/dn(i)=-[summation of ln(n(i)) ]
At maximum dΩ/dn(i) =0 => dΩ =- summation of lnn(i) dn(i) =0
=> summation of lnn(i) dn(i)=0 let this be first equation
Total energy is constant i.e.,
Summation of n(i)*e(i) = constant, => summation of e(i)dn(i)=0 ( 2nd equation) because the summation of change in the total energy level of each state is to zero
Total number of particle is constant
Summation of dn(i)=0 be the third equation
By lagranges method of undetermined multiplication
Multiply 2nd equation by b and 3rd equations by a and add the three equations
We get => summation of [ ln(n (i)) +a + b*e(i) ] d( ni ) =0
And the next step is [ln(n(i)) +a + b*e(i) ] =0..., how is it?
We can't divide both sides dn(i) since the equation is in summation.
Please use the underscore key "_" instead of the word "subscribe". It's standard notation and much easier to read. "e_1" instead of "e(subscribe 1)" and "e^1" instead of "e(superscribe 1)"
Even better, write [ i t e x ] e_1 [ / i t e x ] or [ i t e x ] e^1 [ / i t e x ] (without the spaces) to make e_1 and e^1
Even the https://www.physicsforums.com/Nexus/editor/superscript.png and https://www.physicsforums.com/Nexus/editor/subscript.png from the "Go Advanced" method is better. e.g. e1 or e1
Here's what I think you're saying, but it's hard to read:
Let \Omega = \dfrac{N!}{n_1! n_2! \ldots n_r!}
Using Sterling's approximation, we can write this as:
ln(\Omega) = ln(N!) - \sum_i n_i ln(n_i) - n_i
Now, we want to maximize this subject to the constraints:
  • \sum_i n_i = N, the total number of particles.
  • \sum_i n_i E_i = E, the total energy.
So we use Lagrange multipliers, and maximize
ln(\Omega) - a (\sum_i n_i) - b (\sum_i n_i E_i)
= ln(N!) - \sum_i (n_i ln(n_i) - n_i - a n_i - b n_i E_i)
Now, to maximize, we vary each of the n_i and set the variation to zero. The variation is:
\sum_i \delta n_i (ln(n_i) - a - b E_i)
For this to be zero regardless of the values of \delta n_i, each term in the summation must be zero. So for every i, we must have:
ln(n_i) - a - b E_i = 0
Even if ln(ni)-a-be¡ doesn't equal to zero, then there is chance that summation will be zero doesn't it?why don't we consider that case?
Because, as stevendaryl said, the summation must be zero for arbitrary δni, and this can only be true if each term is zero separately.
For this to be zero regardless of the values of δni, each term in the summation must be zero.
Say for example we have ab+cd +ef =0
We have three cases
1st is (a,c,e)=0
2nd one is (b,c,e)=0
3rd is say for example let ab=3 , cd=5 and ef=-8
What we have done is regardless if value of del(n¡), the second part will zero, yeah i get that but what about other possible cases and why did we took this particular line and preceded?
We have three cases
1st is (a,c,e)=0
The equation we want to solve is:
\sum_i \delta n_i (ln(n_i) - a - b E_i) = 0
We want this to be true for EVERY possible value of \delta n_i. So let's pick a particular value of \delta n_i:
\delta n_{17} = 1
\delta n_0 = \delta n_1 = \ldots = \delta n_{16} = \delta n_{18} = \ldots = 0
So for that value of \delta n_i, the sum simplifies to:
ln(n_{17}) - a - b E_{17} = 0
The only way to make the sum equal to zero for every possible value of \delta n_i is if every term is zero.
You made a mistake the total number of particle is constant therefore if dn_17th is 1 there must be another state dn_i=(-1) that is when you remove on particle from a state you have to add it up to a another system so that
Summation of dn_i=0
Summation of dn_i=0
You're forgetting what the whole point of lagrange multipliers is: Introducing lagrange multipliers allows you to treat the parameters as independent, for the purposes of minimization.
There's one way to see how this works. To start off with, you have r parameters, n_1, n_2, \ldots n_r and you have two constraints: the total number of particles, and the total energy. So there are r-2 independent parameters.
Now, we introduce two new parameters, the two Lagrange multipliers. We don't introduce any new constraints. So now the situation is that we have r+2 parameters, and we have 2 constraints. So there are r independent parameters. We can let those r independent parameters be n_1, n_2, \ldots n_r. Then the two lagrange multipliers are determined by those.
So introducing lagrange multipliers allows us to treat the n_i as independent.
We can work out the very simplest case: just two energy levels e_1 and e_2. In this case, we don't need lagrange multipliers, because the constraints uniquely determine n_1 and n_2:
n_1 + n_2 = N
n_1 e_1 + n_2 e_2 = E
So
n_1 = \dfrac{N e_2 - E}{e_2 - e_1}
n_2 = \dfrac{E - N e_1}{e_2 - e_1}
The Lagrange multiplier approach gives us:
ln(n_1) - a - b e_1 = 0
ln(n_2) - a - b e_2 = 0
So
n_1 = e^{a+b e_1}
n_2 = e^{a + b e_2}
We still have the same constraints:
n_1 + n_2 = N
but these become constraints on a and b:
e^{a + b e_1} + e^{a + b e_2} = N
e_1 e^{a + b e_1} + e_2 e^{a + b e_2} = E
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 16 ·
