Derivations of specific values in Physics
9 replies · 2K views · last reply
Ben Nibarger
I am wondering if anyone knows of a document that shows derivations of specific values in Physics? For example, I need to find μs and am given the distance traveled and time (1.2 km in 17 sec).
I know the equation for μs, Ffriction=μs⋅FN.
I can use this to calculate velocity, etc., but I am at a loss of how to proceed and my textbook doesn't have an example. Mastering Physics doesn't provide a "walk me through a similar problem" feature.
You need to know more than that to solve the problem. I suspect the piece of information you left out is that after these 17 seconds (and 1.2 km) the object ends up at rest?
In the future (and perhaps in your next post) you should copy the whole problem statement, preferably word for word.
In physics, there aren't formulas for every kind of problem; it is up to you to put the pieces together.
I'll help you get started: The equation you wrote for the force of friction says that the force is constant, which means that the acceleration is constant.
Physics is the art of learning how to solve those problems if you are not given the formula to plug in values (that's the part a computer can do).
There has to be more information to solve the problem. Does the object stop at the end?
This is the question: Assuming a constant acceleration and no slipping of tires, estimate the coefficient of static friction needed for a drag racer to cover 1.2km in 17s , starting from rest.
I understand that, I just don't have a strong grasp of the relationships yet. If there was a tool that showed the relationships, or derivations, then it would be easier to understand.
lightgrav said:
so, what "constant acceleration" would be needed?
4.15 m/s2
vavg = Δx/Δt = 1200m/17sec = 70.6 m/s
v = v° + at => v/t = a => 70.59 m/s / 17 s = 4.15 m/s2
You have the equation "Δv/Δt = v/t = a" ... but Δv ≠ vavg. (You used vavg for the Δv). To do it it your way you have to note that vfinal = 2vavg
This is how I think about it:
vavg = 0.5(vfinal+v0) = 0.5(vfinal) = 0.5(a)(Δt) ... [This only applies when v0=0]
vavgΔt = Δx
Put the first equation into the second equation and you get:
0.5(a)(Δt)2 = Δx ... [Again, it only applies when v0=0]Once you get the correct acceleration, you have to figure out what is causing this acceleration. (What is the net force on the car?) Draw a free-body-diagram.
