Derivative of the complex conjugate of z with respect to z
The discussion centers on the derivative of the complex conjugate of a complex variable \( z \) with respect to \( z \) using Wirtinger derivatives. It is established that \( \frac{\partial \overline{z}}{\partial z} = 0 \), indicating that \( z \) and its conjugate \( \overline{z} \) are independent variables. The conversation also addresses the computation of the Jacobian in a system of ordinary differential equations (ODEs) involving complex variables, specifically when the function \( f(a) = cz + d\overline{z} \) is used. Participants conclude that the Jacobian can be computed using real derivatives rather than complex analysis.
  • Understanding of Wirtinger derivatives
  • Knowledge of complex variables and their conjugates
  • Familiarity with ordinary differential equations (ODEs)
  • Basic principles of Jacobian matrices in multivariable calculus
  • Study Wirtinger calculus and its applications in complex analysis
  • Learn how to compute Jacobians for functions involving complex variables
  • Explore the relationship between complex and real derivatives in ODE systems
  • Investigate the implications of Cauchy-Riemann equations in complex analysis
Mathematicians, engineers, and students working with complex analysis, particularly those dealing with ordinary differential equations and Jacobian computations in complex variable systems.
fairy._.queen
Hi all!
From Wirtinger derivatives, given z=x+iy and indicating as \overline{z} the complex conjugate, I get:
\frac{\partial\overline{z}}{\partial z}=\frac{1}{2}\left(\frac{\partial (x-iy)}{\partial x}-i\frac{\partial (x-iy)}{\partial y}\right)=0
This puzzles me, because I cannot see why a number and its complex conjugate could be independent variables.
Thank you in advance!
fairy._.queen said:
Hi all!
If ##\Delta z = h + i k## then ##\Delta \bar{z} = h - ik## (##h,k## real), so
\frac{\Delta \bar{z}}{\Delta z} =\left( \frac{h^2 - k^2}{h^2+k^2}\right) <br /> - i \left( \frac{2kh}{h^2+k^2} \right)
Since the limit as ##h, k \to 0## depends on the "direction", the function ##\bar{z}## is not differentiable in the complex-analysis sense.
Thank you very much for your reply! Then, what about the following situation:
I have an ordinary differential equation system that depends on a number of variables, including z. I have to compute the Jacobian of the function f defining the system, so that I need \frac{\partial f}{\partial z}, but \overline{z} is not a variable for which the algorithm solves.
To simplify things, let's assume I have
and the integrator I'm using needs \frac{\partial f(a)}{\partial z}.
How can I compute that entry of the Jacobian?
Sorry: I have no idea, and I am not sure the problem even makes sense.
I guess it all depends on whether z is some parameter and you need df/dz is the sense of complex analysis, or just in the sense that using z is a convenient way of encapsulating two real variables and you actually have real derivatives. I just cannot tell from the information you supply.
I have a system of complex ODEs, with complex variables.
Let's assume that it looks like this (it's an oversimplification, but will do):
<br /> z&#039; = w+iz\\<br /> w&#039;=c\overline{z}+dz<br />
My algorithm requires me to provide the Jacobian manually, so that I need \frac{\partial w&#039;}{\partial z}.
What can I do?
What can I do?
What does the "prime" stand for (in ##z^{\prime}## for example)?
Derivative with respect to a time variable, i.e. z = z(t), for instance. Thanks!
OK, that is sort of what I suspected.
Assuming t is real, that means that using complex quantities is really just a convenient way of encapsulating real quantities; that is, you can re-write the DE system as a system of coupled DEs for real quantities---similar to what we do in electronics/electrical engineering when we use complex voltages, currents, impedances, etc. You are not really doing "complex analysis", so you don't have to worry about Cauchy-Riemann equations and all that. The Jacobians you need are just ordinary multivariate Jacobians for real functions. Perhaps just re-writing everything in purely real terms would be the least confusing way to go---although it may be much longer (just as in electronics we can always re-write everything in purely real terms, but the expressions get much longer in many cases).
Thanks a lot, it's clear now!
  • · Replies 17 ·
  • · Replies 19 ·
