Deriving charge equation for repelling pith balls
1 reply · 6K views · last reply
rad5brandon
A lab we were recently given in AP Physics class contained an equation already derived. This lab was about determining the charge on a pith ball, using the static charge of a fur to charge the balls negatively, so they repel. Finding the angle and distance between the two balls, the electric charge can be determined.
This is the final equation
q = 2Lsinθ√((mgtanθ)/k)
theta is the measured angle in the experiment (in this case 17 degrees)
m is average mass of the two balls : .2620/2
L is the length of string to the pith ball, bascially the height or radius. Pith ball is hanging from a stand. (.1524 meters)
Fgravitational=Gm1m2/(r^2) Felectricalfield = kq1q2/(r^2)
I've got nothing.
rad5brandon said:
I've got nothing.
Can I assume that the angle θ is the average angle between a given strand and the vertical (as opposed to the total angle between both strands)?
The fist place to start is by drawing a free body diagram.
Then work with the x-components and y-components separately. Since nothing is accelerating, the sum of all forces along a given component must be equal to zero. (For example, the y-component of the tension of a given strand must equal the force of gravity from the corresponding ball). Once you have the force equations for both x and y components, you can combine equations and solve for q (assuming that each ball has the same charge q on it).
Another hint: One of the relevant equations you posted was
Fgravitational=Gm1m2/(r^2)​
There's no need to make it so complicated. Just use
Fgrav = mg​
where m is the mass of the ball, and g ≈ 9.81 m/s2. :wink:
