Deriving Length Contraction From Lorentz Transform
The discussion centers on deriving the length contraction formula using the Lorentz transform and its inverse. It highlights that the equation L_0 = γL is valid only when measurements are taken simultaneously in the moving frame, which is not the case when using the inverse Lorentz transform. The confusion arises because, in the rest frame, the times of the measurements (t1 and t2) do not correspond to the same times in the moving frame due to the relativity of simultaneity. This discrepancy leads to the incorrect conclusion that L = γL_0 if t1 and t2 are assumed to be simultaneous in the rest frame. Clarification is sought on how to correctly apply the inverse Lorentz transform to derive the length contraction formula, emphasizing the need to account for time differences.
Delzac
From Lorentz Transform,
<br /> x^{\prime} = \gamma (x - vt)<br />
From textbooks and wikipedia,
L_0 = x&#039;_2 - x&#039;_1 = \gamma (x_2 - x_1 )
Where x_1 and x_2 = L
Thus,
\L_0 = \gamma L
Question is this:
If i take the same method and us the Inverse Lorentz transform, i seem to get a different answer, namely:
\L = \gamma L_0
Which obviously is wrong. I suspect the problem is with where the observing is that is implicitly assume when one use either Lorentz or inverse Lorentz. But, i cannot be sure nor can i resolve this problem.
Any help will be appreciated.
Note that this is only true if t1=t2. To put it another way, (x1,t1) represents the event of measuring x1 while (x2,t2) represents the event of measuring x2. In the reference frame where the stick is moving, the two measurements have to be performed at the same time. They don't have to be performed at the same time in the rest frame--no matter when you measure x1' or x2', they're always going to be the same.
Question is this:
\L = \gamma L_0
Here, you're assuming that t1=t2, where both are rest frame coordinates. (Otherwise, the right-hand side would not equal L_0.) However, if t1=t2, t1' does not equal t2' because of relativity of simultaneity! Unlike in the previous case, neither x1' nor x2' remain the same as time passes, so x2'-x1' does not equal L.
Ah, i see. Thanks, got it.
But, then how dose one use Inverse Lorentz Transform to get length contraction formula? Since t' is not the same, so we use the lorentz transform for t'?
