Deriving of the constants in Fourier Analysis
The discussion focuses on deriving constants in Fourier Analysis, specifically the coefficients \(a_n\) and \(b_n\) from the Fourier series representation of a function \(v(t)\). The equations provided include \(v(t) = a_0 + \sum_{n=1}^N a_n \cos(nwt) + \sum_{m=1}^M b_m \sin(mwt)\) and the integrals used to calculate \(a_n\) and \(b_n\). The integrals equal zero due to properties of odd and even functions, where the sine function is odd and the product of an odd function with an even function is also odd. This leads to the conclusion that certain integrals vanish when evaluated over symmetric limits.
  • Understanding of Fourier series and Fourier Analysis
  • Knowledge of integral calculus, particularly definite integrals
  • Familiarity with properties of odd and even functions
  • Experience with LaTeX for mathematical typesetting
  • Study the derivation of Fourier coefficients in detail
  • Learn about the properties of odd and even functions in mathematics
  • Explore advanced topics in Fourier Analysis, such as convergence of Fourier series
  • Practice using LaTeX for typesetting complex mathematical equations
Students and professionals in mathematics, physics, and engineering who are studying Fourier Analysis, as well as educators looking to enhance their understanding of mathematical functions and their properties.
PsychonautQQ
Wow LaTex fail... anyone know how i make this look like not ****? I had it looking all pretty on http://www.codecogs.com/latex/eqneditor.php and it gave me these codes as my latex markup but it didn't come out right... why do they look like source code and not the pretty equations they are supposed to?
Fourier Analysis equation:
$\displaystyle v(t)=a_0 + \sum_{n=1}^N a_ncos(nwt) + \sum_{m=1}^M a_msin(mwt)
\displaystyle a_n= \frac{2}{T}\int\limits_{\frac{-T}{2}}^{\frac{T}{2}}v\(t)cos(nwt)\, dt
\displaystyle b_n= \frac{2}{T}\int\limits_{\frac{-T}{2}}^{\frac{T}{2}}v\(t)sin(mwt)\, dt
To show that the coefficients a and b are given by the equations above, we multiply v(t) by cos(2∏kt/T) and integrate with respect to time from t = -T/2 to t = T/2
\displaystyle \int\limits_{\frac{-T}{2}}^{\frac{T}{2}}\ ((a_0+\sum_{n=1}^N a_n cos(\frac{2\pi nt}{T}) +\sum_{m=1}^M b_m sin(\frac{2\pi mt}{T}))
which will give us three types of integrals
\displaystyle a_0\int\limits_{\frac{-T}{2}}^{\frac{T}{2}}cos\frac{2\pi kt}{T}\,\ dt=0
\displaystyle \sum_{m=1}^M b_m\int\limits_{\frac{-T}{2}}^{\frac{T}{2}}sin\frac{2\pi mt}{T}cos\frac{2\pi kt}{T}dt=0
\displaystyle \sum_{n=1}^N a_n\int\limits_{\frac{-T}{2}}^{\frac{T}{2}}cos\frac{2\pi nt}{T}cos\frac{2\pi kt}{T}dt= T/2 (n=k)
My question is why do the first two of these three integrals equal zero?
(first time using LaTex holy crap took forever
Assuming I'm deciphering the equations correctly, then the first integrals equal zero because the integral will be a sin function, and between the limits you will always have integer multiples of pi for any k (sin k*pi = sin(-k*pi) = 0)
The second integral is zero because it is an odd function integrated between symmetric limits. (an odd function multiplied by an even function is an odd function).
$$\displaystyle v(t)=a_0 + \sum_{n=1}^N a_ncos(nwt) + \sum_{m=1}^M a_msin(mwt)$$
$$\displaystyle a_n= \frac{2}{T}\int\limits_{\frac{-T}{2}}^{\frac{T}{2}}v\(t)cos(nwt)\, dt$$
$$\displaystyle b_n= \frac{2}{T}\int\limits_{\frac{-T}{2}}^{\frac{T}{2}}v\(t)sin(mwt)\, dt$$
$$\displaystyle \int\limits_{\frac{-T}{2}}^{\frac{T}{2}}\ ((a_0+\sum_{n=1}^N a_n cos(\frac{2\pi nt}{T}) +\sum_{m=1}^M b_m sin(\frac{2\pi mt}{T}))$$
$$\displaystyle a_0\int\limits_{\frac{-T}{2}}^{\frac{T}{2}}cos\frac{2\pi kt}{T}\,\ dt=0$$
$$\displaystyle \sum_{m=1}^M b_m\int\limits_{\frac{-T}{2}}^{\frac{T}{2}}sin\frac{2\pi mt}{T}cos\frac{2\pi kt}{T}dt=0$$
$$\displaystyle \sum_{n=1}^N a_n\int\limits_{\frac{-T}{2}}^{\frac{T}{2}}cos\frac{2\pi nt}{T}cos\frac{2\pi kt}{T}dt= T/2 (n=k)$$
Use $$ instead of $. More here:https://www.physicsforums.com/showpost.php?p=3977517&postcount=3
So sin is an odd function then? Why is cos * sin an odd function? I can't find any good explanations on google.
P.S thanks Tsny
It is kinda simple, just like multiplying numbers, an odd times an even number results in an odd number.
If you want a more rigorous definition then you can go back to the definition of odd and even. Assume g(x) is odd and f(x) is even.
Then the product h(x)= f(x)*g(x). To check the parity of h(x) we find h(-x)= g(-x)*f(-x).
Remembering what it means to be an odd or even function we get g(-x)*f(-x)= -g(x)*f(x)= -h(x).
Leaving you with h(x)= -h(-x); otherwise known as an odd function.
  • · Replies 27 ·
  • · Replies 17 ·
