Deriving the Rate of Change of Angle in a Rocket Launch Using Differentiation
  • Thread starter Thread starter Bostonpancake0
    Differentiation
5 replies · 2K views
Bostonpancake0
The question is as follows:
A rocket was launched straight up, and its altitude is given by h = 10 t2 m after t
seconds. You are on the ground 300 m from the launch site watching the rocket going
up. The line of sight from you to the rocket makes an angle θ with the horizontal. By
how many radians per second is θ changing 10 seconds after the launch?
I guess my question is whether my understanding of the problem and working is correct. I'm not 100% confident on my process and my answer and am just wondering if I have missed anything important.
By working and answer is tagged below.
Looks okay when my head is turned sideways. If you want to be picky, you could show working out for how you differentiated to get dh/dt. It's not necessary but the grader might deduct points off that, in which I had suffered first hand experience from that.
Ahhh yes thanks for that missed it, alright its just that 11degrees a second seems rather large? I tried it another way and got d(theta)/d(t)=60*t/t^4+900...then subbing t gives me d(theta)/d(t)=0.055046 degrees/sec? doesn't this seem like a more likely answer?
I think the left side of your page should be dθ/dh
When t = 5 secs, h = 10(5)^2 = 250m
When t = 10 secs, h = 1000m
When t = 15 secs, h = 2250m
When t = 20 secs, h = 4000m
Hi I think I am doing the same assignment as you. I got the same values that dh/dt= 20t, d(theta)/d(h)= 60t/t^4+900 and multiplying them gets d(theta)/d(t)= 1200/109. But I agree, I thought it was too high. But then i tried differentiating d(theta)/d(h) and then subing in h=10t^2 afterward and it got a much lower answer which i believe is correct. Because the original way, we were differentiating dh/dt at the same time as d(theta)/d(h). DON'T FORGET TO CONVERT INTO RADIANS THOUGH! You didn't do this on the sheet. Good luck!
