Designing Double Reduction Gear Drive: Input RPM 730, Output RPM 85.7
  • Thread starter Thread starter fahadiliciouz
    Gear Reduction
The discussion revolves around the design of a double reduction gear drive, focusing on the challenges of achieving sufficient bending strength given specific input and output RPMs, torque, and material properties. Participants explore various design considerations, including material selection and adherence to AGMA standards.
  • One participant notes the need for higher bending strength due to high bending stress resulting from input torque and suggests changing materials to achieve this.
  • Another participant inquires whether calculations are based on AGMA standards or basic machine design principles and suggests modifying gear geometry as a potential solution.
  • A participant confirms the use of AGMA standards and provides specific dimensions for pitch diameter and face width, considering a material with higher tensile strength.
  • There is a suggestion that changing materials is a straightforward approach to increase bending strength, with a query about the pitting resistance of the design.
  • One participant emphasizes that the design is theoretical and does not include pitting resistance, focusing solely on bending strength and stress.
  • Another participant explains that AGMA standards consider hardness rather than just strength and recommends using a material with a higher hardness value, mentioning E9310 Ultra-High Strength Steel as an example.
  • A participant raises a question about the surface factor required for calculating bending strength and its dependence on material processing methods.
  • One participant asserts that in practice, the surface factor is typically considered to be 1 and notes that AGMA standards do not specifically address it.
Participants generally agree on the importance of material selection for achieving adequate bending strength, but there is no consensus on the specific material to use or the treatment of the surface factor in calculations.
Limitations include the theoretical nature of the design, the exclusion of pitting resistance in calculations, and the lack of consensus on the appropriate surface factor for materials.
fahadiliciouz
i have to design a double reduction gear drive using a spur gear pair.Input RPM is 730 and output RPM is 85.7. s The pinion teeth are 18 and the module is 3. The problem is that the input torque is 144Nm due to which i am getting a very high tangential velocity (Ft) which results in a higher values of bending stress both for pinion and gear and the values for my bending strength are comparatively lower to the bending stress so i am getting a factor of safety that is below 0. The steel i am using to calculate bending strength is AISI 1050 tensile strength 725 MPa.
Can anyone advise me what changes should i make to get a higher value of bending strength.
Are you using some sort of program or AGMA standards to calculate this, or is it basic Machine Design type stuff?
If the former, you can try increasing the addendum on the gear and decreasing it on the pinion.
What limitations do you have? Is material set? Pitch diameter? Face width?
yes it is based on AGMA standards i used AISI 1050 steel which is hot rolled..
pitch diameter according to the values i gave you is 54 mm for the pinion and 159mm for the gear and the face width is 60mm.
what i was thinking was to use a steel which has a higher tensile strength compared to what i stated above so that i can get a higher value of bending strength..
what do u think ?
Changing materials really is the easiest way to get more bending strength. How does the pitting resistance look?
well my design is theoretical so pitting resistance is not included. u just have to find factor of safety using bending strength and bending stress...
according to what u said that changing materials would resolve the problem so can u suggest a material which can b used for gears and which has a very high tensile strength...
the AGMA standards include two "strength" factors; one is bending, the other is pitting. They coincide and are theoretically based upon geometry, operation and material.
Anyways, in gear design, they really base all of their measurements on hardness rather than strength. Simply find a material with a higher hardness value. We recently analyzed a part that was made out of E9310 Ultra-High Strength Steel. It has a hardness value of HRC 58.
the steel you mentioned that is 29310 ultra-high strength steel is double quenched...while finding the bending strength we require the surface factor which is based on a graph where we measure the surface factor using harness number and whether the steel is forged, hot rolled or machined.
So i wanted to know where can you find the surface factor for this material
In practice, the surface factor, [tex]C_f[/tex] is typically just 1. In fact, looking through my literature, the AGMA standards do not address the surface factor (also called [tex]Z_r[/tex]), so IMHO, just leave it 1.
15K
13K
