Determinant of matrix of linear transformation
freetonik
Linear transformation T: P2->P2
T(f) = -5f + 8f'
Need to find detA (A is a matrix of T)
T(f) = Af
The basis of P2 is B={1, x, x2}. Some polynomial f with respect to B looks like this in general:
(a, b, c)T
right? So, T(f) = -(a, b, c)T + 8 (0, b, 2c)T = (-a, 7b, c)T.
So, A*(a, b, c)T = (-a, 7b, c)T, therefore A =
1 0 0
0 7 0
0 0 1
And detA = -7. This is how I was thinking about it, but the answer is wrong and I am confused :(
What happened to the factor of 5 from T(f)=-5f+8f'?
Oh!
Thanks!
It always happens to me.
So, fixing that mistake, T(f)=
-5a
3b
11c
And A becomes:
-5 0 0
0 3 0
0 0 11
and detA = -165 and it is still wrong :(
Well, if f(x)=a+bx+cx^2, then f'(x)=b+2cx
So, if you are representing your basis functions as
x^0\to\begin{pmatrix}1 \\ 0 \\ 0 \end{pmatrix} \;\;\;\;\text{and}\;\;\;\; x^1\to\begin{pmatrix}0 \\ 1 \\ 0 \end{pmatrix} \;\;\;\text{and}\;\;\;\; x^2\to\begin{pmatrix}0 \\ 0 \\ 1 \end{pmatrix}
Then you have f(x)\to\begin{pmatrix}a \\ b \\ c \end{pmatrix} and f'(x)\to\begin{pmatrix}b \\ 2c \\ 0 \end{pmatrix}
Okay, thank you again!
Now I have:
-5(a, b, c)T + 8 (b, 2c, 0)T =
-5a+8b
-5a+16c
-5a
And:
A(a, b, c)T = (-5a+8b, -5a+16c, -5a)T, so A=
-5 8 0
-5 0 16
-5 0 0
detA = -640 and it is still wrong :(((
Now I have:
-5a+8b
-5a+16c
-5a
Errm...
-5\begin{pmatrix}a \\ b \\ c \end{pmatrix}+8\begin{pmatrix}b \\ 2c \\ 0 \end{pmatrix}=\begin{pmatrix}-5a+8b \\ -5b+16c \\ -5c \end{pmatrix}
Oh, I'm dumb! Thank you very much!
There is a similar problem I cannot figure out..
T(f(t)) = f(2t) - 3f(t)
Again need to find detA.
In this case I don't even know how to start...
Is T again a mapping from P2 to P2?
If so, do it in the same way, just with t as the variable instead of x... if f(t)=a+bt+ct^2, what is f(2t)?
f(2t) = a + b2t = c2t2?
No. If f(t) = a + bt + ct2, then f(2t) = a + b*2t + c(2t)2. This can be simplified.
Sorry, I've faced one more problem...
There is T: R2->R2, s.t. T(V1)=8V2, and T(V2)=-4V1.
Need to find detA.
This is how I started thinking:
AV1=8V2 => A=8V2 / V1
AV2=-4V1 => A=-4V1 / V2
Don't know how to think further...
Okay, and what are V_1 and V_2?
They are just some vectors in R2, they're not given.
I don't believe that. If this was true for all V_1 and V_2 in \mathbf{R}^2, then the matrix A would have to be full of zeroes. You'd need only look at some case where V_2=V_1 to prove that to yourself.
I suspect that they are supposed to represent the basis vectors of \mathbf{R}^2. In which case, you might as well look at two orthogonal basis vectors
V_1\to\begin{pmatrix}1 \\ 0 \end{pmatrix} \;\;\;\;\text{and}\;\;\;\; V_2\to\begin{pmatrix}0 \\ 1 \end{pmatrix}
freetonik said:
This is how the problem stated:
http://imgur.com/bU4b7.png
Okay, so they are some specific vectors, you just aren't told exactly what they are.
In that case, just say
V_1\to\begin{pmatrix}a_1 \\ b_1\end{pmatrix} \;\;\;\;\text{and}\;\;\;\; V_2\to\begin{pmatrix}a_2 \\ b_2\end{pmatrix}
and go from there.
