Determine Jupiter radius based on graviational acceleration at surface
The discussion focuses on calculating Jupiter's radius using gravitational acceleration and the orbital characteristics of its moon, Europa. The gravitational acceleration at Jupiter's surface is given as 2.36 times that of Earth's, leading to the equation GMJ/r² = 2.36g. To find Jupiter's radius, the centripetal acceleration of Europa, derived from its orbital period and distance from Jupiter, is equated to the gravitational force acting on it. The calculations involve determining the angular velocity of Europa and relating it to the gravitational force, ultimately leading to a proposed radius of approximately 74,038 km for Jupiter. Understanding the relationships between gravitational and centripetal forces is crucial for solving this problem.
WannaLearn
1. The problem:
The moon Europa, of the planet Jupiter, has an orbital period of 3.55 days and
an average distance from the center of the planet equal to 671,000 km. If the
magnitude of the gravitational acceleration at the surface of Jupiter is 2.36
times greater than that on the surface of the Earth, what is the radius of
Jupiter? (Hint: begin by calculating the rotation speed.)
2. Homework Equations
F=GMjMm/R^2
v=2piR/T
3. The Attempt at a Solution
Not sure at all. I guess, the centripital force of the mon Europa has to be equal to the gravitational force. MeV^2/R=GMeMj/R^2, but then I am not sure what to do with the given gravitational acceleration of Jupiter and how to get the r-radius of jupiter.
I appreciate any help.
This is sort of a two step problem.
Step 1.)
Look at the first relevant equation (which appears to have a typo of one too many masses, but anyway...)
The right side of that equation has Jupiter's radius in it, which is the thing you want to solve for. Given that on Jupiter's surface the acceleration is 2.36 g, what can you write the left side of the equation as? (Hint: If you were on the surface of the earth, what would you write it as? How does this change on Jupiter?)
Step 2.) Hint: You'll need to use the info given about Jupiter's moon to calculate the piece of information you aren't directly given for the resulting equation in step 1. That's where you use the info from your suggested solution...
Step 1.)
Thank you pastro.
Step 1. 2.36g=G/r^2 ?
I found a solution to this problem in one of the previous posts, but there are few things I do not understand.
Solution:
radius of orbit of Europa, rm = 671000km
rotational period of Europa, T = 3.55 days
Acceleration due to gravity on Jupiter = GM/r² = 2.36g
radius of Jupiter, r = ?
Rotational velocity of Europa, ω = 2π/(3.55*86400) radians/second - WHY IS THERE NO 'r' v=2πr/T
Centripetal acceleration, a =rmω² - ISN'T IT a=v^2/r?
Gravitational acceleration on Europa
=GM/(rm)²
=(GM/r²)*r²/(rm)² - I DO NOT UNDERSTAND WHAT HAPPENS HERE/WHERE THIS EQUATION COMES FROM =(2.36g)(r/rm)²
Equating gravitational acceleration with centripetal acceleration,
(2.36g)(r/rm)² = rmω²
r=(rm)³ω²/(2.36g)
=74,038 km
Could somebody please explain. I am trying to understand. Any help.
Perform dimensional analysis and you'll see you're still missing something. Should be:
2.36g = GMJ/r2
So you need to know the mass of Jupiter, which is the unknown quantity I referred to before.
ω is the angular velocity, not the linear velocity. In this case, you can think of angular velocity as the angle through which an object rotates divided by the time it takes to rotate through that angle. Since you are given the period (which means a rotation by 2π = 180 degrees), then ω is as you show.
Note that linear velocity is related to angular velocity by the relationship v = ω r, which I use to answer your next question.
This is a bit confusing, be cause you use rm, which appears to stand for "Jupiter-moon distance," not r m = distance times mass. Anyway, I'll make this distance rm to avoid confusion.
v = ω rm, so a = v2/rm = (ω rm)2/rm = ω2rm
