Determine the car's displacement
  • Thread starter Thread starter etSahcs12
    Displacement
The discussion focuses on calculating the displacement of a car traveling at varying velocities over a 15-second period. The car initially moves at 18 m/s for 5 seconds, accelerates uniformly to 24 m/s over 4 seconds, and then travels at 24 m/s for an additional 6 seconds. The key equations used include d = vt for constant velocity and d = ut + 1/2 at² for acceleration. The final displacement is determined by summing the distances covered in each segment of the trip.
  • Understanding of kinematic equations, specifically d = vt and d = ut + 1/2 at²
  • Basic knowledge of velocity and acceleration concepts
  • Ability to perform calculations involving time, distance, and speed
  • Familiarity with average speed calculations
  • Research the derivation and application of kinematic equations in physics
  • Learn how to calculate average speed in uniformly accelerated motion
  • Explore real-world applications of displacement calculations in automotive physics
  • Study examples of multi-segment motion problems in physics textbooks
Students studying physics, particularly those focusing on kinematics, as well as educators seeking to clarify concepts related to motion and displacement calculations.
etSahcs12
Hi, I am new to the fourm. If it is not any touble, please help me with a kinematic problem.
A car travels east along a straight road at a constant velocity of 18 m/s. After 5.0s, it accelerates uniformly for 4.0s, reaching a velocity of 24 m/s. For the next 6.0s, the car proceeds with uniform motion. Determine the car's displacement for the 15.0s trip.
Δd = v1 x Δt + 1/2 x acceleration x Δt(squared)
Δd = v2 x Δt - 1/2 x acceleration x Δt(squared)
Δd = 1/2 (v1 + v2) Δt
2aΔd = v2^2 - v1^2
a = v2 - v2 / Δt
This is the only question I have not experienced before. Please guide me through this question.
You will have to split the problem into 3 parts. There are two where the car is traveling with a constant velocity and one where it is accelerating. The equation you have stated is almost correct. For constant velocity you will need:
d = vt
For constant acceleration you will need one of the constant acceleration kinematic equations.
https://www.physicsforums.com/showpost.php?p=905663&postcount=2
so do i do:
18 m/s x 5.0s then 24 x 4.0s then add them up?
What do i do with the 6.0s and the uniform motion? When adding do i find the displacement?
etSahcs12 said:
so do i do:
No. The two time intervals when the car is traveling with constant velocity are the first 5 seconds and the last 6 seconds after the acceleration. To work out the distance traveled while accelerating you will need one of the kinematic equations in the link I gave you above. To save you the time here it is:
d = ut +\frac{1}{2} at^2
How am i able to find the acceleration and v1 by using all of these variables (specifically time and velocity)? Would i use d = vt at all?
etSahcs12 said:
am i supposed to divide this question into 3 parts as well?
Which question are you talking about? You have posted on question and were told to break it into 3 parts.
Okay, how far will it go at 18 m/s for 5 s?
Hint: at uniform acceleration, the "average speed" is just the average of the lowest and highest speeds: (18+24)/2 m/s. How far will the car go in 4.0s at that average speed?
At 24 m/s how far will the car go in 6.0 s? NOW add them all up.
Ohh i see. If i were to add them, I would get the displacement correct? or should i use d = ut +\frac{1}{2} at^2 after adding.
You can ignore that one, I made a mistake. You will need to use the average velocity as HallsofIvy suggested in d = vt.
so, bastically i do d = vt with the time and velocities, add them up and that's my displacement?
Please help me with this proble. I have tried everything.
A rifle is aimed horizontally at a target located 44.0 m away. The bullet hits the target 3.0 cm below the aim point. What was the bullet's time of flight?
Yes but remember the middle time stint will require you work out the average speed.
Please do not hijack other peoples threads. You can start a new thread of your own if you have a question.
I see, so after adding 24+18 and dividing by 2, multply the time and that will be my distance ? Once done, do the same for the other 2 (but without finding the average acceleration) and add, thus giving my displacement?
Yes.
  • · Replies 22 ·
