Determine the gas if the pressure of its saturated steam is known
The discussion focuses on determining the identity of gas B and mineral A based on experimental data of saturated steam pressure and density at various temperatures. The Mendeleev-Klapeiron equation, M = ρRT/p, was employed to calculate molar masses, revealing inconsistencies as temperatures increased. Participants emphasized the need for clarity on the relationship between gas and matter, noting that gas B exhibits different structures in liquid and gaseous phases. The conversation highlights the importance of accurate data interpretation in physical chemistry.
  • Understanding of the Mendeleev-Klapeiron equation
  • Familiarity with concepts of saturated steam pressure
  • Knowledge of gas density and relative density calculations
  • Basic principles of physical chemistry and phase transitions
  • Research the application of the Mendeleev-Klapeiron equation in real-world scenarios
  • Explore methods for determining gas identities using pressure and density data
  • Investigate the physical properties of gases and their behavior under varying temperatures
  • Study the relationship between molecular structure and phase behavior in gases
Chemists, physicists, and students in physical chemistry, particularly those interested in gas behavior, phase transitions, and the application of thermodynamic equations.
beruniy
One hundred thousands denarii (or 423 kg of gold) cost a vase from mineral A in Ancient Rome. A Painter in 17th century occasionally got from it gas B and Physicist in 19th told an assumption of its composition.
There are experimental data of pressure of its saturated steam and density over a liquid at different temperatures:
T, oC 0 20 40 60 80 100
p, mm m.c. 363,8 773,2 1516 2778 4801 7891
ρ, g/l 2,015 3,170 4,976 7,645 11,44 16,64
and also data of relative density at different temperature in gaseous phase for this matter:
T, oC 26,4 29,2 33,1 39,2 47,3 88,1
p, mm m.c. 745 750 750 743 745 741
D, air 1,773 1,578 1,321 1,002 0,823 0,713
1) Determine gas A and mineral B
2) Determine compound and structure of this matter in gaseous phase
3) Describe physical properties and give the examples of chemical properties of this compound (reactions with different classes: simple matters, oxides, salts, hydroxides, acids)
4) What was the names of Painter and Physicist?
Points 2), 3) and 4) of this task I can solve if I know what the matters A and B. So it is necessary to solve point 1).
I tried to use Mendeleev-Klapeiron equation, through density it becomes following:
M = ρRT/p
But for each occasion I've got... different molar masses! Explain please if it's possible?
I've got the next data:
M, g/mole 94,3 74,9 64,1 57,1 52,5 49,0
It means that during of temperature raising molar mass is decreasing. But it's impossible!
May be, I need to use another equations?
Dear sirs,
I've detected an error in my post. I am sorry.
I mixed up mineral and gas.
1) Determine mineral A and gas B
I also want to say that gas and matter have the same meaning - it is B. I think that problem says that B has different structures in liquid and gaseous phase. All the data relate to B.
I have only one question: how is it possible to determine gas B using pressures of its saturated vapour and relative densities?
