MHB How Many Cafes Should Be Surveyed for Accurate Daily Turnover Estimates?
  • Thread starter Thread starter mathmari
The discussion focuses on determining the minimum number of cafes that must be surveyed to ensure that the sample mean deviates from the expected turnover of €600 by less than €12 with a 95% confidence level. Using Chebyshev's inequality, it was initially calculated that at least 125 cafes are needed. However, a more precise calculation using the Central Limit Theorem revealed that a sample size greater than 24 is sufficient. Additionally, a survey of 500 cafes yielding a mean of €690 indicates that the assumed parameters for expected value and standard deviation are likely incorrect, as evidenced by a p-value significantly less than 0.05.
  • Understanding of Central Limit Theorem
  • Familiarity with Chebyshev's inequality
  • Knowledge of hypothesis testing and p-values
  • Basic statistics concepts including mean and standard deviation
  • Study the Central Limit Theorem in depth
  • Learn about hypothesis testing and significance levels
  • Explore the implications of the Finite Population Correction Factor
  • Investigate methods for calculating sample size for different confidence levels
Statisticians, data analysts, researchers conducting surveys, and anyone involved in statistical sampling and hypothesis testing will benefit from this discussion.
mathmari
MHB
Hey! :o
The daily turnover $X$ of Cafes has the expected value $ \mu_X = 600 $ Euro and the standard deviation $ \sigma_X = 30 $ Euro.
(a) How many cafes at least have to be surveyed in a random sample, so that $\overline{X}_n$ deviates from $\mu_X$ with a probability of at least $95\%$ by less than $12$ euros?
(b) After a survey of $500$ Cafes the arithmetic mean is $690$. Is this result surprising after the question (a) ?
I have done the following:
(a) From Chebyshev's inequality we have that \begin{equation*} P\left (\left |\overline{X}_n-E(\overline{X}_n)\right |< \epsilon\right )\geq 1-\frac{V(\overline{X}_n)}{\epsilon^2}\end{equation*} with $E(X_n)=\mu_X=600$ and $V(X_n)=\frac{\sigma_X^2}{n}=\frac{30^2}{n}=\frac{900}{n}$.
It must hold \begin{align*} P\left (\left |\overline{X}_n-600\right |< 12\right )\geq 95\% &\Rightarrow 1-\frac{V(\overline{X}_n)}{12^2}\geq 95\% \\ & \Rightarrow 1-\frac{\frac{900}{n}}{144}\geq 0.95 \\ & \Rightarrow 1-0.95\geq \frac{\frac{900}{n}}{144} \\ & \Rightarrow 0.05\geq \frac{25}{4n} \\ & \Rightarrow n\geq \frac{25}{4\cdot 0.05} \\ & \Rightarrow n\geq 125\end{align*}
That means that at least $125$ Cafes have to be surveyed. Is this correct?
(b) Why does not hold when number of the surveyed Cafes is $500$ ? (Wondering)
Hey mathmari!
(a) Unfortunately Chebyshev's inequality only gives a very wide result.
We can do better. (Thinking)
Since both the expected value and the standard deviation are given, the distribution of the sample mean is $\overline X_n \sim N(\mu_X, \frac{\sigma_X}{\sqrt n})$.
Therefore we have:
$$P(|\overline X_n - \mu_X| < 12) = P\left(\frac{|\overline X_n - \mu_X|}{\sigma_X/\sqrt n} < \frac{12}{\sigma_X/\sqrt n}\right)
= P\left(|Z| < \frac{12}{\sigma_X/\sqrt n}\right)$$
The critical z-value for a confidence interval of $95\%$ is $z^*=1.96$.
Therefore the critical sample size $n^*$ satisfies:
$$z^* = \frac{12}{\sigma_X/\sqrt {n^*}}=1.96\quad\Rightarrow\quad n^*=24.0$$
Thus we need a sample size $n>24$. (Wink)(b) Are we surprised to see the much larger deviation $\overline x - \mu_X = 690-600=90$ when the number of surveyed Cafes is $n=500$?
Yes! It means that our assumed expected value and standard deviation are likely not correct!
Can we calculate the probability how confident we are that they are incorrect? (Wondering)
Therefore we have:
I understand! We use here the Central Limit Theorem, or not? (Wondering)
How can we calculate that probability? (Wondering)
That's one way to look at it.
Then again, suppose that $X_1, ..., X_n$ are indendent random variables with the same distribution $N(\mu_X,\sigma_X)$.
Then:
$$\sigma^2\left(\frac 1n(X_1+...+X_n)\right) = \frac 1{n^2}\left(\sigma^2(X_1) + ... + \sigma^2(X_n)\right) = \frac {\sigma_X^2}n
\quad\Rightarrow\quad \sigma(\overline X) = \frac{\sigma_X}{\sqrt n}
Isn't it? (Wondering)
In other words, the standard deviation of the sample means $\sigma_{\overline X}$, which is also called the standard error $SE$, is:
$$SE=\sigma_{\overline X} = \frac{\sigma_X}{\sqrt n}$$
Pick the null hypothesis $H_0: \mu=600, \sigma=30$, and the alternative hypothesis $H_1: \mu\ne 600 \lor \sigma\ne 30$.
Then assuming $H_0$, $\overline X$ has the normal distribution $N(600, \frac{30}{\sqrt{500}})$ for a sample size of $n=500$.
What is:
$$P(|\overline X-600| > |690 - 600|)$$
? (Wondering)
Then:
I see! (Nerd)
What is:
? (Wondering)
Do we calculate this probability using the significance level? Or am I thinking in a wrong way? (Wondering)
Sure. Let's pick $\alpha=0.05$, although I'm really interested in the so called p-value that we can compare with $\alpha$. (Thinking)
We have that $$P(|\overline X-600| > |690 - 600|)=P(|\overline X-600| > 90)=1-P(|\overline X-600| \leq 90)$$ Do we use here the distribution function of the normal distribution?
I got stuck right now. (Wondering)
Yep.
We have:
$$p = P(|\overline X-600| > |690 - 600|)=P\left(\frac{|\overline X-600|}{30/\sqrt{500}} > \frac{90}{30/\sqrt{500}}\right)
\approx P\left(|Z| > 67.1\right) \approx 0.00000
Since $p<\alpha$, we can reject $H_0$.
Conclusion
The daily turnover $X$ of Cafes has an expected value $μ_X\ne 600$ Euro and/or standard deviation $σ_X\ne 30$ Euro ($p < 0.00000$). (Thinking)
Let's also not forget the Finite Population Correction Factor. 125/600 = 21%ish. The standard rule is about 5% max. Something must be done. If you have the right circumstances, your analysis can suggest sampling more than the entire population unless you correct it for the absence of an infinite population.
If we're sampling a significant fraction of the population, doesn't $\sigma_{\overline X}$ just go down even further?
Making the conclusion of rejecting the null hypothesis only more significant?
You cannot extend this argument forever with a finite population.
1) Eventually, your sample will exceed your population.
2) Once you have sampled the entire population, you no longer have a sample. It's a census. There is no longer ANY sampling error.
3) At times, sampling is SO EXPENSIVE that it is simply not practical to proceed. I once assisted in a court case where we needed statistical significance that would convince the court. It was a population of about 450. Without the FPCF, the sample was calculated to be about 600! That's obviously no good. With the FPCF, an appropriate and convincing sample was about 14. MUCH better.
Even without the practical concerns, with a finite population, the assumption of Normality is less clearly met. Worrying about Bias in your estimator leads to a different and unbiased test statistic. Guess what one such test statistic is? :-)
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 77 ·
12K
