What Sample Size Ensures a 95% Confidence Interval Length of 5?
  • Thread starter Thread starter toothpaste666
    Sample size
To ensure a 95% confidence interval length of no more than 5 when estimating a population mean with a known standard deviation of 18, the sample size can be calculated using the formula n = [(z_(α/2) σ)/E]^2, where z_(α/2) is 1.96 for a 95% confidence level and E is the maximum error. Substituting the values, E is set to 5, leading to a calculated sample size of approximately 49.8. The discussion emphasizes the importance of understanding the distribution of the sample mean and the relationship between sample size and confidence intervals. Ultimately, the correct sample size ensures the desired precision in estimating the population mean.
toothpaste666
An investigator, interested in estimating a population mean, wants to be sure that the length of the 95% confidence interval does not exceed 5. What sample size should she use if σ = 18?
the formula I found in my book is n = [(z_(α/2) σ)/E]^2
z_(α/2) = z.025 = 1.96
I am fairly certain if the length of the interval can't exceed 5, then 5 will be the max error so
E = 5
n = [1.96(18)/5]^2 = 49.8
Am I doing this correctly?
E = 5
Avoid using canned formulas; rather, work things out from first principles. So ask yourself: if ##X_1, X_2, \ldots, X_n## are iid random variables from the distribution ##N(\mu,\sigma^2)##, what is the distribution of the sample mean
\bar{X} = \frac{1}{n} \sum_{i=1}^n X_i \: ?
Now you need to know how large to make ##n## in order to have
P(-2.5 \leq \bar{X} - \mu \leq 2.5 ) = 0.95,
assuming that you know ##\sigma = 18##. At that point you are ready to state with absolute confidence the appropriate test to use. (And no, I will not tell you if you are correct or not!)
since
P(-z_(α/2) ≤ (X-μ)/(σ/sqrt(n)) ≤ z_(α/2)) = .95
P(-z.025 ≤ (X-μ)/(18/sqrt(n)) ≤ z.025) = .95
-1.96 ≤ sqrt(n)(X-μ)/18 ≤ 1.96
-1.96(18)/(X-μ) ≤ sqrt(n) ≤ 1.96(18)/(X-μ)
[-1.96(18)/(X-μ)]^2 ≤ n ≤ [1.96(18)/(X-μ)]^2
n = [1.96(18)/(X-μ)]^2
which is what I got before if E = (X-μ)
I think it does, but I am now not sure if it is equal to 5
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
  • · Replies 22 ·
