Graduate How Does the Non-Equality of Kernels Imply Their Sum Equals the Vector Space?
  • Thread starter Thread starter Portuga
    Kernel
The discussion revolves around a linear algebra exercise regarding the relationship between the kernels of two linear transformations, F and G, and their implications for the vector space V. The kernel and image theorem establishes that the dimensions of the kernels and images are related, leading to the conclusion that if the kernels are not equal, their sum must equal the entire vector space. Participants express confusion about why the non-equality of the kernels implies that their sum spans V. Clarification is provided that since the dimension of the sum must be at least n, this confirms the relationship. The discussion concludes with a realization of the simplicity of the concept.
Portuga
TL;DR
Let ##F## and ##G## be two non-zero linear functionals over a vector space ##V## of dimension ##n##. Assuming ##ker (F ) \neq \ker (G)##, determine the dimensions of the following subspaces: ##\ker (F )##, ##\ker (G)##, ##\ker (F ) + \ker (G)##, and ##\ker (F ) \cap \ker (G)##.
This is actually a solved exercise from a Brazilian book on Linear Algebra. The author presented the following solution:
The kernel and image theorem tells us that dimension ##\dim V=n=\dim\ker\left(F\right)+\dim \text{im}\left(F\right)=\dim\ker\left(G\right)+\dim\text{im}\left(G\right)##. As ##\text{im}\left(F\right)\subset R##, ##\dim\mathbb{R}=1## and ##F\neq0##, then ##\dim\text{im}\left(F\right)=1##. Similarly ##\dim\text{im}\left(G\right)=1##. Therefore, ##\dim\ker\left(F\right)=\dim\ker\left(G\right)=n-1##. On the other hand, the dimension theorem of the sum assures us that
\dim\left(\ker\left(F\right)+\ker\left(G\right)\right)+\dim\left(\ker\left(F\right)\cap\ker\left(G\right)\right)=\dim\ker\left(F\right)+\dim\ker\left(G\right)=2n-2.
In general, ##\ker\left(G\right)\subset\ker\left(F\right)+\ker\left(G\right)## and due to the hypothesis ##\ker\left(F\right)\neq\ker\left(G\right)##, we will have ##\ker\left(F\right)\begin{array}{c}
\subset \\ \neq \end{array}\ker\left(F\right)+\ker\left(G\right)##; then necessarily ##\ker\left(F\right)+\ker\left(G\right)=V##. So ##\dim\left(\ker\left(F\right)+\ker\left(G\right)\right)=n## and hence
\dim\left(\ker\left(F\right)\cap\ker\left(G\right)\right)=\left(2n-2\right)=n-2.
I am ok with almost everything he presented, but couldn't understand why
the hypothesis ##\ker\left(F\right)\neq\ker\left(G\right)## implies that ##\ker\left(F\right)+\ker\left(G\right)=V.##
Any ideas?
Thanks in advance.
Do you understand why ##ker(F)\subsetneq ker(F)+ker(G)##?
Since the left hand side has dimension n-1, the right hand side must have dimension n or higher.
Oh my god! It was so simple!
Thank you very much!
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 24 ·
