Determining the inverse function for a given function
To determine the inverse function of f(x) = (2x + 1)^3 - 2, the correct steps involve first rewriting the equation as y = (2x + 1)^3 - 2 and then switching x and y to get x = (2y + 1)^3 - 2. The next step is to isolate y by adding 2 to both sides, resulting in x + 2 = (2y + 1)^3, and then taking the cube root of both sides. After rearranging, the final expression for the inverse function is f^-1(x) = (cube root(x + 2) - 1) / 2. Correctly following these steps ensures the accurate determination of the inverse function.
steve snash
Determine the inverse function for the function,
f(x)=((2x+1)^3)-2
I think i know the steps but i want to know if my answer is correct
1.Change f(x) to f(y)
2.Re write so x=f(y)
3.Swap x and y variables
4.replace y with f^-1(x)
1.y=((2x+1)^3)-2
2.cube sqrt y=(2x+1)-2
=cube sqrt y+2=2x+1
=cube sqrt y+1=2x
=(cube sqrt y+1)/2=x
3.y=(cube sqrt x+1)/2
4.f^-1(x)=(cube sqrt x+1)/2
Is this right? Can someone please tell me how to do it if its wrong?
It would be easiest if you just switch the x and y variables at the start (don't deal with f(x) and f(y) etc. while solving the equation), and then once you found the answer, change your y into f-1(x).
y=((2x+1)^3)-2
No! \sqrt[3]{((2x+1)^3-2}\neq (2x+1)-2
To illustrate this, I'll give you a more basic example that's a common mistake. Take pythagoras' theorem: c=\sqrt{a^2+b^2}. Now, many students that come across this formula outside of solving lengths for right-triangles often make the mistake that \sqrt{a^2+b^2}=a+b since they can just take the square root of each term inside... WRONG!
Obviously if this were true we would have simplified pythagoras' theorem to c=a+b :-p
The rule is \sqrt{x^2}=x and x can be just about anything you choose, such as a+b. But then (a+b)^2=a^2+2ab+b^2\neq a^2+b^2. Only until you can convert (2x+1)^3-2 into a^3 where a is some variable involving x, then can you take the cube root.
But this is impossible, so all you need to do is move the -2 over to the other side, then you can take the cube root.
So how do you change the (2x+1)^3-2 so x=y (eg) how do you find the answer?? I am confused :p
I remember also thinking that inverse functions were tricky when I started.
Your function is y = (2x+1)3-2.
To find the inverse, switch x and y so that you get x = (2y+1)3-2.
Now the tricky bit is rearraging this so you have it in terms of y. So we need y = ...
First add 2 to both sides, then you'll be on your way.
f(x)=((2x+1)^3)-2
1.y=((2x+1)^3)-2
You have the order wrong. If you were evaluating this for some specific x, you would subtract 2 last so finding the inverse, you add 2 first:
y+ 2= (2x+ 1)^3. Now take the cube root of both sides.
=cube sqrt y+2=2x+1
And please don't say "cube sqrt"- the "sqrt" or "square root" is specifically the inverse of squaring. What you want here, the inverse of cubing is "cube root".
=cube sqrt y+1=2x
You should have, at this point, cube root(y+ 2)= 2x+1. Solve that for x.
