Determining whether the series is convergent or divergent
The series defined by the summation ∞∑(((2n^2 + 1)^2)*4^n)/(2(n!)) from n=1 is determined to be convergent using the Ratio Test. The limit derived from the Ratio Test simplifies to 0/4, which is less than 1, confirming convergence. The dominant terms in the numerator and denominator were analyzed, leading to the conclusion that the series converges as n approaches infinity.
  • Understanding of the Ratio Test for series convergence
  • Familiarity with factorial notation and its properties
  • Knowledge of asymptotic notation, specifically Big O notation
  • Ability to manipulate algebraic expressions involving limits
  • Study the application of the Ratio Test in greater detail
  • Explore other convergence tests such as the Root Test and Comparison Test
  • Learn about asymptotic analysis and its implications in series
  • Practice solving similar series convergence problems involving factorials
Students studying calculus, particularly those focusing on series and sequences, as well as educators teaching convergence tests in mathematical analysis.
umzung
Determine if the series is convergent.
∑ (((2n^2 + 1)^2)*4^n)/(2(n!))
n=1[/B]
I'n using the Ratio Test and have got as far as (4*(2(n+1)^2+1)^2)/((n+1)((2n^2+1)^2)). I know this series converges but I need to find the limit to be < 1 to show this. Is there way to now divide each term by the dominant term n^2, or do I need to multiply the whole thing out and divide by the new dominant term? I've tried that and have found the limit to be 0/4 = 0.
Just note that the numerator goes as ##8n^4 + \mathscr O(n^3)## and that the denominator goes as ##4n^5 + \mathscr O(n^4)## as ##n\to \infty##. This will be sufficient.
n=1[/B]
If you want to show the algebra, you can do something like this:
$$\frac{4}{n+1}\frac{[2(n+1)^2+1]^2}{(2n^2+1)^2}
=\frac{4}{n+1}\frac{\left[(n+1)^2\left(2+\frac{1}{(n+1)^2}\right)\right]^2}{\left[n^2\left(2+\frac{1}{n^2}\right)\right]^2}$$ so you don't have to multiply everything out.
