Diff. eq. solve linear equation
Jtechguy21
Solve the following differential equations.
3xy'+y=12
I believe this is a linear equation problem. So I believed to have solved it, however I am not sure if I have done so correctly.
Handwritten solution to a first-order linear differential equation, problem 5, 3xy' + y = 12, with integrating factor work, the integral of 4x dx, and a final answer y = 6x + c/(3x).
If you're not sure, take the derivative and you can verify it from the equation given. The only mistake I see is in calculating your integrating factor:
When you have [itex]e^{\frac{1}{3}lnx}[/itex], you have to move the 1/3 into the exponent on the [itex]lnx[/itex] before you cancel the e and the ln.
thank you for the advice.
I see what you mean. so when the e and the ln cancel out, i should be left over with x^(1/3) as my integrating factor correct?
Yes, that looks right. That should give you the right answer.
