Difference between particle density and quantum density operators
3 replies · 3K views
Liao Chen
I'm confused about the two density operators:
\rho=\sum_{i}\delta(r-r_{i}) and \rho=\sum_{i}|\psi_{i}>\rho_{ii}<\psi_{i}|
Is there anyone explaining this question to me? Thanks very much.
The first one is not normalized if your sum has more than one term.
Thanks a lot. Do you mean the two density operators are the same and connected through some transformations? Could you explain with a little more details?
After some thinking I really do not know what the first expression could mean. It does not make any sense to me. If I consider it as an operator, it would act as
[tex](\rho\psi)(x')=\int \delta(x-x_i)\psi(x)dx=\sum_i\psi(x_i)[/tex]
which is a number and not a function. For a continuous spectrum the formula should look like
[tex](\rho\psi)(x')=\int \rho(x',x)\psi(x)dx[/tex]
So, where did you get it from?
