Difference equations steady states (Problem in the last step)
sid9221
http://dl.dropbox.com/u/33103477/model.png
Form of the equation
\gamma -\delta p_t = \frac{p_{t-1}-\alpha}{\beta}
or
p_t = \frac{-1}{\delta \beta}p_{t-1} + \frac{\alpha + \gamma \beta}{\delta \beta}
So the steady state is p^* = \frac{\alpha + \gamma \beta}{\delta \beta + 1}
For the steady state to be stable it should tend to zero hence
\alpha + \gamma \beta < \delta \beta + 1
or \alpha + \beta \gamma - \beta \delta < 1
Now the general solution from the def of a steady state can be given by:
P_n = (\frac{-1}{\delta \beta})^n [1-\frac{\alpha + \gamma \beta}{\delta \beta + 1}] + \frac{\alpha + \gamma \beta}{\delta \beta + 1}
Subbing in values:
P_n = (\frac{-5}{6})^n [\frac{-9}{11}] + \frac{20}{11}
So say I put P_n = (\frac{20}{11} - \frac{1}{100}) ie within a penny(approaching downwards)
than [\frac{-5}{6}]^n = \frac{11}{900}
Which can't be solved as log of negative is the "end of the universe". So where am I going wrong ?
The condition for the steady state to be stable might be wrong but that's a secondry issue, is there anyway I can get the minus out cause without it I get an reasonable answer of around 24 days..
or
Subbing in values:
You might not be able to get to exactly one penny away from equilibrium in an integer number of periods. However, you do want to get *within* one penny of equilibrium. Your P_n fluctuates above and below equilibrium, so you need
\left|P_n - \frac{11}{20} \right| \leq \frac{1}{100}, hence
\frac{9}{11} \left| \left(\frac{-5}{6} \right)^n \right| \leq \frac{1}{100},
or \left(\frac{5}{6} \right)^n \leq \frac{11}{900}.
RGV
Thank you, can you tell me if my condition for stability of the steady state is ok ?
