Different types of hyperbolas and their properties
29 replies · 4K views
Gourab_chill
The question along the answer is given in the attachments. What I seek is the explanation.
---not sure---
I know the hyperbola of the form x^2/a^2-y^2/b^2=1 and xy=c; but coming across this question I'm put in a dilemma of how to proceed with calculating anything of it - say eccentricity or latus rectum or transverse axis as said. How to generalize a hyperbola (but i don't want a complex derivation of hyperbolas because that's out of my understanding, i want to get across these questions; teach me the fundamentals) and find it's different values or parameters?
Hi,
Fair enough. So no references like this :smile: ?
In that case you can fall back to a very useful action: make a sketch like I did:
Blue is your hyperbola, red is the asymptotes and on the brown line is the transverse axis.
With such a nice :cool: sketch it is clear what you need to do to calculate the required value !
Other approach: calculus.
@BvU looks neat; but here is the problem how do I know what is the equation of the transverse axis? And how do I calculate the quantities like eccentricity, latus rectum length? What should be my approach?
You know the equations of the asymptotes
And I admit the others are beyond my recollection (if I even ever encountered them). Will you look them up or should we do that for you :wink: ?
However, might be there's no escaping
Gourab_chill said:
complex derivation
then :nb)
Ok so I will give you a hint.You shall proceed further.Since the given equation contains xy term,therefore it is clear that the hyperbola has been rotated.
So to get back to the original form of hyperbola,substitute
X=xcosA+ysinA
Y=xcosA-ysinA
or any other substitution you prefer.
Now,you must be able to proceed further.
You are not asked for the equation, only the length.
You can see from @BvU's beautiful sketch that it's the closest approach to the origin. Just a little calculus...
@Gourab_chill : did you find the asymptote equations ? Then you can also find the line for the transverse axis and then finding the marked point doesn't even require any calculus !
haruspex said:
beautiful sketch
:blushing: too much credit -- just Excel
X=xcosA+ysinA
Y=xcosA-ysinA
Is this not the correct way @haruspex @BvU
X=xcosA+ysinA
Y=xcosA-ysinA
Not quite.
Change the equation for Y. The pair of equations becomes:
##X=x\cos A+y\sin A##
##Y=y\cos A-x\sin A##
Perhaps this is what you intended.
The brown line is a bit too suggestive, going through ##(1,-0.5)##.
The green dash-dot lines represent the correct axes:
So you'll need an intersection of the green line and the hyperbola.
Not by coincidence the slope of that green line is ##\ -\tan(A)\ ## in @SammyS post #9
There is no one correct way. Even what is the easiest way may depend on what the solver is most comfortable with.
To me, what I outlined in post #6 seemed easier than figuring out the rotation.
SammyS said:
Not quite.
yes.That was a typo.Sorry for that.
@Physics lover Your post is a good one. Especially for the case of ## xy=1##, the best way of looking at it IMO is the rotation of axes by 45 degrees which does put it in the standard form: ##\frac{x'^2}{a^2}-\frac{y'^2}{b^2}=1 ##, with ##a=b=\sqrt{2} ##. ## \\ ## Without this result, someone might think that there are different types of hyperbolas. I believe they can all be put in the standard form with the necessary rotation and/or translation.
I still favour
##x^2+y^2=2x^2-2+\frac 1{x^2}=2u-2+\frac 1u##, where u=x2.
Then it is just a matter of finding the minimum of that and taking the square root.
haruspex said:
I still favour
@haruspex Yes, your way is easier, but I successfully worked it by considering the rotation. It took a little work to get the answer given by the OP, but I got it.
The rotation is 22.5° .
haruspex said:
I think @Charles Link was just applying it to the example of xy=1, not the hyperbola in the question.
@Charles Link showed a way of solution for the problem in the OP. And the hyperbola is really rotated by 22.5 degrees clockwise with respect to a hyperbola of standard from x2/a2-y2/b2=1
Yes, the green line in the picture in #10.
I was surprised that the tangent of ##\pi/8## has a value ##\ \sqrt2 - 1 \ ## (wasn't in my dusty brain archive :biggrin:)
In our enthousiasm, have we lost @Gourab_chill ? What's the status with you ?
https://www.mathsisfun.com/geometry/hyperbola.html
That's not how I read Charles' post.
He endorsed the rotation method, but then illustrated it for a different hyperbola, xy=1, for which the rotation is 45°. @SammyS seems to have misread this as saying that the rotation in the thread problem is 45°. But we might have to wait for Charles to confirm or deny.
But your brain archive
certainly has sin, cos or tan of ##\pi/4## and you can derive ##\tan(\pi/8)## easily from the double angle formula
$$\tan(\pi/4)=\frac{2\tan(\pi/8)}{1-\tan^2(\pi/8)}=1$$
or the half-angle formulas
$$\sin(\pi/8)=\sqrt{\frac{1-\cos(\pi/4)}{2}}$$ and
$$\cos(\pi/8)=\sqrt{\frac{1+\cos(\pi/4)}{2}}$$ :smile:
He endorsed the rotation method, but then illustrated it for a different hyperbola, xy=1, for which the rotation is 45°. @SammyS seems to have misread this as saying that the rotation in the thread problem is 45°. But we might have to wait for Sammy to confirm or deny.
When I first did my post responding to @Physics lover and showed the case of ## xy=1 ##, (and 45 degree rotation), I hadn't yet read the thread carefully enough to see the OP had an attachment that contained the more complicated ## y=x-\frac{1}{x} ##. ## \\ ## I later solved the OP's problem, by computing ##\cos{\theta} ## so that the ## x'y' ## term vanishes, and then finding where the line ##y=(\tan{\theta})( x )## intersects the curve ##y=x-\frac{1}{x} ##, and finally computing the distance of that point from the origin. @haruspex does have a simpler solution.
Based on above diagram, if equation of hyperbola is f(x), solve simultaneously:
y=f(x)
y=-x/f'(x)
ie: f(x) = -x/f'(x)
I think Haruspex went the same way (largely) (?)
You can solve ##y=f(x) ## and ##y=-tan(A) \, x ##, but
@haruspex assumes the graph originates from the origin. He takes the distance ## s ## as ## s^2=x^2+y^2 ## and cleverly substitutes for ## y ## with ## y=x-\frac{1}{x} ##, so that he has ##s^2 ## as a function of ## x ##, (see post 14). He then minimizes ## s^2 ##, obtaining the value for ##x ## where the derivative is zero. Next, solve for ##y ##, and compute ## s ##.
Oh - ok. I am solving by assuming the minimized line passes through the origin and is perpendicular to the hyperbola.
I didn’t assume it, but neither did I include that part of the proof.
If you switch x to -x and y to -y in the equation for the curve you get the same equation back. Therefore it is symmetric about the origin.
@neilparker62 For your method, (with the curve being perpendicular to the line), you can solve ##(f'(x))(-\tan(A))=-1 ##, which also gets a correct solution.
Just an add-on to the "proof" (see post 26) by @haruspex . What follows is essentially the same thing, but it might make it easier to follow: ## \\## Let ##(x_{old}, y_{old} ) ## be a point on the curve. It satisfies ##y_{old}=x_{old}-\frac{1}{x_{old}} ##. ## \\ ## Let ## x_{new}=-x_{old} ##. We have the corresponding ## y_{new}=x_{new}-\frac{1}{x_{new}}=-x_{old}+\frac{1}{x_{old}}=-y_{old} ##, so that ## y_{new}=-y_{old} ##. Thereby, in general, if ## (x,y) ## is on the curve, ##(-x, -y) ## is also on the curve. (It may be a separate branch of the curve, but it's still the "curve"). ## \\ ## Getting the original equation with the substitution ## x=-x ## and ## y=-y ## is essentially the same thing, but the reader might find this alternative method to be useful.
