Differential equation with cross product
The discussion centers on solving the differential equation (d²R/dt²) + (dR/dt) x B = 0, where R is a position vector in the x-y plane and B is a constant vector in the z-direction. Participants suggest rewriting the equation as a system of first-order differential equations, utilizing eigen-vector decomposition for constant coefficient matrices. The conversation emphasizes the importance of understanding the relationship between the components of R and the magnetic field B, particularly in the context of electron motion in a magnetic field.
  • Understanding of vector calculus and differential equations
  • Familiarity with cross products and their applications in physics
  • Knowledge of eigen-vector decomposition for solving systems of equations
  • Basic concepts of motion in magnetic fields, particularly in classical mechanics
  • Study the method of eigen-vector decomposition for systems of differential equations
  • Learn about the physical implications of motion in magnetic fields, specifically the Lorentz force
  • Explore techniques for converting higher-order differential equations into systems of first-order equations
  • Investigate the role of constants in differential equations and their impact on solutions
Students and professionals in physics, particularly those focusing on classical mechanics and electromagnetism, as well as mathematicians dealing with differential equations and systems analysis.
alsey42147
ok, i don't know what to do with something like this:
(d^2R/dt^2 ) + (dR/dt) x B = 0
where the capitals are vectors (sorry i suck at latex). R is a position vector in x-y plane and B is in the z-direction.
do i split this into equations for x and y directions separately and solve them? for x-direction i would get
d^2x/dt^2 + (dy/dt)|B| = 0
but how do i solve this? I'm pretty sure all the DEs I've ever solved had, for example, d^2x/dt^2 and dx/dt in them, but not d^2x/dt^2 and dy/dt.
or is there a quick way of doing it without having to expand the cross product?
any help would be well appreciated!
This is a SYSTEM of differential equations that you can rewrite as:
\frac{d\vec{U}}{dt}=A\vec{U}, \vec{U}=\frac{d\vec{R}}{dt}
and A is a matrix.
If A has constant coefficients, then the system is readily solvable with eigen-vector decomposition.
Question:
Did you get this equation from a physical problem with a Coriolis term?
Just curious..
EDIT:
Insofar as B is constant, you may gain two decoupled 3.order diff.eq's in R (i.e 2.order in U).
Maybe \vec{B} is the magnetic field and he chose units such as q=1...
damn, i wish i was more proficient with matrices and stuff. i might have to do a bit of quick revision.
the equation is just electron motion in a magnetic field without the constants.
my friend says that from the equation
you just integrate to get
dx/dt + y|B| = constant
that doesn't seem quite right to me...is it? if it is that's all i need for now.
Is B a constant, or a function of x and y?
Yes, writing R as <x, y, 0> you get
\frac{d^2x}{dt^2}+ B\frac{dy}{dt}= 0
and
\frac{d^2y}{dt^2}- B\frac{dx}{dt}= 0[/itex]<br /> <br /> You can, as Arildno suggested, introduce u= \frac{dx}{dt} and v= \frac{dy}{dt} and write this as a system of 4 first order differential equations.<br /> <br /> Another way to handle it is this: differentiate the first equation again to get<br /> \frac{d^3x}{dt^3}+ B\frac{d^2y}{dt^2}= 0[/itex]&lt;br /&gt; and use the second equation to substitute for the second derivative of y&lt;br /&gt; \frac{d^3x}{dt^3}+ B^2\frac{dx}{dt}= 0&lt;br /&gt; That&amp;#039;s easy to solve.&lt;br /&gt; &lt;br /&gt; Once you know x(t), you can use the first equation to solve for \frac{dy}{dt} and integrate once more to find y(t).&lt;br /&gt; &lt;br /&gt; (I just noticed J77&amp;#039;s comment. I am assuming here that B is a constant.)
awesome, thanks. and yes B is constant.
You can certainly use your friend's trick in the case of constant B. It doesn't help you an overly lot, though, compared to other techniques mentioned.
  • · Replies 16 ·
