Differential Equations of form y'(x)=f(ax+by+c)
The discussion focuses on solving the differential equation of the form y'(x) = f(ax + by + c), specifically y'(x) = sqrt(3x - 4y + 2). Participants explore the substitution v = ax + by + c to transform the equation into a separable form. The key insight is that the integral ∫(dv/(3 - 4√v)) can be solved using substitution techniques, leading to a solution involving logarithmic and square root functions. The final solution is expressed in terms of y and x, demonstrating the effectiveness of substitution in solving complex differential equations.
  • Understanding of differential equations, specifically first-order equations.
  • Familiarity with substitution methods in integration.
  • Knowledge of integral calculus, including logarithmic and polynomial integrals.
  • Experience with algebraic manipulation and simplification techniques.
  • Study the method of substitution in solving differential equations.
  • Learn about integral calculus techniques, focusing on polynomial long division.
  • Explore advanced integration techniques, including trigonometric and hyperbolic substitutions.
  • Practice solving separable differential equations with varying functions f(v).
Students and educators in mathematics, particularly those studying differential equations and integral calculus, as well as anyone looking to improve their problem-solving skills in advanced calculus topics.
khkwang
My professor states that a differential equation of form y'(x)=f(ax+by+c) can be reduced to a separable equation by substituting in v=ax+by+c, but I don't see how.
Edit: more specifically: y'(x)= sqrt(3x -4y +2)
y'(x)=f(ax+by+c)
v=ax+by+c
If v=ax+by+c, then dv/dx = a + b*dy/dx
Then dv/dx = a + b*f(v)
But this isn't a separable differential equation... the constant a is in the way.
dv/dx = 3 - 4*sqrt(v)
Does
\displaystyle\int \frac{dv}{a + bf(v)} = \displaystyle\int dx
not work?
yeah, i was about to post that I'm a moron for not realizing such a solution a few moments ago...
But now I'm stuck on how to solve
\displaystyle\int \frac{dv}{3 - 4\sqrt{v}} = \displaystyle\int dx
I just solved that particular integral by hand. I don't know if I should give away the method I used yet. It's an easy straightforward one, once you see what to do. No trigonometric substitution or anything like that, obviously.
I'll give it another shot. If i still can't figure it out in a while, I'll ask again?
Edit:
I think I solved it, but it's a little messy
<br /> \displaystyle\int \frac{dv*(3 + 4\sqrt{v})}{9 - 16v} = \displaystyle\int dx<br />
<br /> \displaystyle\frac{-3*\ln{|9-16v|}}{16} + \frac{\sqrt{v}}{2} + c = x<br />
<br /> \displaystyle\ln{|64y - 48x -23|} - \frac{8\sqrt{3x - 4y + 2}}{3} - \frac{16x}{3} + c = 0<br />
Is this good?
That method seems a little messy.
x = \int \frac{dv}{3-4\sqrt{v}} = \int \frac{3+4\sqrt{v}}{9-16v}dv
x = \int \frac{3}{9-16v}dv + 4 \int \frac{\sqrt{v}}{9-16v}dv
x = - \frac{3}{16}\ln|9-16v| + 4 \int \frac{\sqrt{v}}{9-16v}dv
I fear the second integral is not equal to sqrt(v)/2.
My suggestion would have been to use the substitution u = sqrt(v), then the integral becomes
x = \int \frac{2u}{3-4u}du
which is the same as
x = \int \left( - \frac{1}{2} + \frac{3/2}{3-4u}\right) du
I think. Might want to double check the division.
Ahh substitution. It seems obvious now lol thanks.
But can you tell me how you brought the 1/2 out of the last equation to get rid of the extra u? I can see that the last two equations are equivalent, but I don't understand the process. Did you just guess at taking -1/2 out? Or is there some basic rule I'm forgetting? On another problem right now i need to get the integral of (2u + 1)du/(5u + 5). Would the same steps apply there?
Edit: Scratch helping me solve (2u + 1)du/(5u +5), I figured it out using the same method you showed me. Still, could you tell me if that process has a name? I don't feel like I've ever been taught it before. Or is it just supposed to be obvious to the student?
Cheers
  • · Replies 21 ·
  • · Replies 18 ·
