rollingstein
- 644
- 16
algar32 said:2c+3d+zb=0
This one's wrong I think.
-2c+3d+zb=0
What's rref BTW?
rollingstein said:Nevertheless, how about this: The global minimum has to occur either at one of the local minima or at the boundary of the domain (including ±∞).
In this case, analytical differentiation reveals only two optima.
The only other limit is x,z --> +∞ but that offers no better cost function (it blows up actually).
At this point am I not assured that I have a global minimum? What makes your strategy necessary or is that only an alternate way of saying what I just said?
algar32 said:If I am just solving for b I don't understand why I can't use rref in the calculator? Can you confirm that the following is the correct system of equations is correct?
-2c -3d +xb=0
4c+4d+4b=981
2c+3d+zb=0
ussing rref: I am getting b to be equal to 2943/(x-5)*(z-2.4) . Is this what I am looking for (b in terms of x and z)?
Thanks.
rollingstein said:What actually happens if we do let x,z lie where 5x + z + 12 =0.
Is that a statically indeterminate structure?
algar32 said:when I use rref I get : b = 2943/(5x+z+12)
Is this correct?
voko said:Correct.
voko said:It is not correct to call limits at infinity global extrema, because the function never attains such values. It is not correct to call ±∞ a boundary, either.
These are not optima, these are critical points till you analyze them further.
You are forgetting the boundary of the domain: 5x + z + 12 = 0.
You have an open domain. You can show that the function is continuous and differentiable there. That still does not guarantee that a global minimum exists. You have to prove in one way or another that there is a global minimum. My approach is in a way simplest because it does not require any advanced technique - not even calculus - to prove that.
Where does this part come from?voko said:Indeed b > 0 is a physical constraint that must be satisfied. This constrains the domain of the cost function. And it must be minimized in that domain.
For a general multivariate function, global minimization is a very difficult problem. In this case, however, the problem can be analyzed with elementary means. Let's take some value k and see if the cost function can be less than that: i.e.,
(x^2 + z^2 +16)/(5*x+z+12) < k
(x^2 + z^2 +16) < k(5*x+z+12)
(x^2 + z^2 +16) - k(5*x+z+12) < 0
x^2 - 5kx + (2.5k)^2 - (2.5k)^2 + z^2 - kz + (0.5k)^2 - (0.5k)^2 + 16 - 12k < 0
(x - 2.5k)^2 - (2.5k)^2 + (z - 0.5k)^2 - (0.5k)^2 + 16 - 12k < 0
(x - 2.5k)^2 + (z - 0.5k)^2 - 6.5k^2 - 12k + 16 < 0
It is obvious that the minimum of the left-hand side expression is -6.5k^2 - 12k + 16, so -6.5k^2 - 12k + 16 < 0. What does this inequality mean? It means that for any k satisfying it, there are lesser values of the cost function, i.e., this value is not minimal.
There are two ranges of k satisfying this inequality: ## k > 4 \frac {\sqrt{35} - 3 } {13} ## and ## k < -4 \frac {\sqrt{35} + 3 } {13} ##. The second range is invalid, because we require that the cost-function be positive, so we have only one range, and that means that ## \displaystyle k = 4 \frac {\sqrt{35} - 3 } {13} ## is the greatest value, for which no lesser value exists, i.e., it is the global minimum. And it is exactly the value you obtained for the local minimum, so the local minimum is also global.
rollingstein said:In hindsight, I hope it didn't sound like I was criticizing your approach, sorry!
algar32 said:Where does this part come from?(x^2 + z^2 +16)/(5*x+z+12) < k
I see that you have squared each of the coordinates for b on top and divided by the denominator of what we solved for b.
voko said:Recall how the cost function was defined. It was tension multiplied by length. What are these, now that b has been determined?
algar32 said:The length should be sqrt(Sqrt(z^2+x^2)^2 +y^2)^2
I see that someone squared it to get length squared (x^2+z^2+16)... I don't know why this was done.
rollingstein said:I did it to make life easier. r^2 should attain a minimum at the same spot r does for r>0.
Don't know how rigorous that isl.
rollingstein said:At this point, haven't I exhausted any possibility that there's any global minimum outside of the set I enumerated? Is there anything else that'd be needed?
The tension on b we know to be 2943/(5x+z+12).
voko said:## b ## is not the tension. Recall how it is related to tension.
algar32 said:b is a function of x and z. I don't recall it's relation to tension.
voko said:Review #7.
Okay thanks :)rollingstein said:In hindsight I was wrong. That is not the reason for " someone squared it to get length squared ".
I was just lucky!Two wrongs made a right!
algar32 said:Okay thanks :)
rollingstein said:It got squared because the other identical square root came from the tension term.
I mistakenly assumed all other than b was a unit vector. It was not.
algar32 said:I am told b is not equal to tension, but is related and I was never quite sure of the relation. B is just some made up positive constant. So how can I find tension from what I have done thus far?
rollingstein said:On further thought, if b>0 why do we not need to also ensure that c>0 and d>0?
They all being chains violation of these constraints would cause one of the other chains to go slack too?
Or are those constraints automatically met?
Shouldn't we be adding constraints like x+z=0 and x-z=0?
rollingstein said:Think harder.![]()
algar32 said:Not sure this helped :(. Could you point me in the right direction?
rollingstein said:Formula for Magnitude of a vector? Tension's a vector.
