Dimensional analysis - atomic bomb explosion radius
7 replies · 3K views
vector
:[/B]
An atomic explosion can be approximated as the release of a large amount of energy ##E## from a point source. The explosion results in an expanding spherical fireball bounded by powerful shock wave. Let ##R## be the radius of the shock wave and assume that ##R=f(E,T,\rho_0, p_0)## where ##t## is the elapsed time after the explosion takes place, ##\rho_0## is the ambient air density and ##p_0## is the ambient air pressure. Using dimensional analysis show that ##R=\frac{Et^2}{\rho_0}g(\pi_1)## where ##\pi_1## is a dimensionless variable. Choose it so that it involves ##E## to a negative exponent. What is ##\pi_1##?
The problem is that the relationship does not appear to be homogeneous. If ##\pi_1## is dimensionless, then the units of ##\frac{Et^2}{\rho_0}## must be the same as the units of ##R##. However,
##[E] = ML^2 T^{-2}##
##[t] = T##
##[\rho_0] = ML^{-3}##
##[p_0] = ML^{-1}T^{-2}##
##[R]=L##, where M is express in kilograms, T is in seconds, L is in meters.
What is it that I'm not getting right here?
On the other hand, I expressed ##\pi_1## as follows: ##\pi_1 = \frac{p_0 R^3}{E}##. Is this correct?
Thank you!
##[t] = T##
Thank you!
yes, it's correct. The dimension ##p_0 R^3## is same for E.
##ML^{-1}T^{-2}## * ##L^{3}## = ##ML^2T^{-2}##
Thanks. But do you think the expression given in the problem statement is correct at all? The problem is that ##R## has units of ##L##, but ##\frac{Et^2}{\rho_0}## has units of ##L^{-5}##.
unit of ##Et^2## is ##ML^2T^{-2} * T^2## then ##ML^2##
so unit of ##R## is ##\frac{ML^2}{ML{-3}}## = ##L^5##
Sorry, I meant ##L^5##. So then the expression is not quite homogeneous. Namely, the units of ##R## are ##L##, but the units of ##\frac{ET^2}{\rho_0}## are ##L^5##. Am I correct?
yes , you are. Below file can be useful
http://dspace.mit.edu/bitstream/handle/1721.1/42045/228875559.pdf?sequence=1
Thanks. So, the ##\frac{ET^2}{\rho_0}## should be raised to the power of 1/5, shouldn't it?
yes, it's right
