Dimensionality of total angular momentum space
The discussion revolves around the dimensionality of total angular momentum space for a system of two electrons, one in the state characterized by quantum numbers n=1, l=0 and the other by n=2, l=1. Participants explore the implications of angular momentum addition in quantum mechanics.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the calculation of total angular momentum states using the formula (2j_{1}+1)(2j_{2}+1) and question the correctness of their interpretations of angular momentum combinations. There are attempts to clarify the allowed values of total angular momentum j and the corresponding magnetic quantum numbers m_j.
The conversation is ongoing, with participants providing insights and corrections to each other's reasoning. Some participants have offered guidance on the addition of angular momenta, while others express confusion about the implications of their calculations. Multiple interpretations of the problem are being explored.
There are indications of misunderstandings regarding the addition of angular momenta and the quantum states involved. Participants are also navigating the complexities of distinguishing between different quantum numbers and their respective states.
xago
There are 2 electrons, one with n=1, l=0 and the other with n=2, l=1. The question asks what is the dimensionality of total angular momentum space.
I know for 2 electrons (spin 1/2 each) the possible values of total spin are s=0 or s=1.
the total angular momentum is l=0 + l=1 = 1 (right?)
So does this mean that j1 = 1+0 and j2 = 1+1
which gives a dimensionality of (2(1) +1)(2(2) +1) = 15??
The number seems a little off to me, perhaps the equation I have for dimensionality is incorrect?
Take the s=0, l=1 combination. Your formula says there are (2s+1)(2l+1) = 3 total states. Those states are
\begin{align*}
&\vert s=0,\ m_s=0;\ l=1,\ m_l=1\rangle \\
&\vert s=0,\ m_s=0;\ l=1,\ m_l=0\rangle \\
&\vert s=0,\ m_s=0;\ l=1,\ m_l=-1\rangle.
\end{align*}The other way to look at it is to sum the angular momenta together, ##\vec{J} = \vec{S} + \vec{L}##. According to the rules of addition of angular momenta, there is only a single allowed value for j, namely j=1, so there are 2j+1 = 3 states, corresponding to mj = 1, 0, and -1. Either way you get three states.
Now you do the s=1, l=1 combination. What are the allowed values of j?
\begin{align*}
So if I understand correctly, j= l+s = 2 for l=1, s=1 which means that the possible values of m_{j} are -2,-1,0,1,2 which gives the possible states of:
\begin{align*}
&\vert s=1,\ m_s=-1;\ l=1,\ m_l=1\rangle \\
&\vert s=1,\ m_s=-1;\ l=1,\ m_l=0\rangle \\
&\vert s=1,\ m_s=-1;\ l=1,\ m_l=-1\rangle \\
&\vert s=1,\ m_s=0;\ l=1,\ m_l=1\rangle \\
&\vert s=1,\ m_s=0;\ l=1,\ m_l=0\rangle \\
&\vert s=1,\ m_s=0;\ l=1,\ m_l=-1\rangle \\
&\vert s=1,\ m_s=1;\ l=1,\ m_l=1\rangle \\
&\vert s=1,\ m_s=1;\ l=1,\ m_l=0\rangle \\
&\vert s=1,\ m_s=1;\ l=1,\ m_l=-1\rangle.
\end{align*}
which gives 9 states total... (including the 3 states in the middle there which are the same as the ones given by s=0)
No, that's not correct. I think you need to go back and study the addition of angular momenta as you seem to have some basic misunderstandings about angular momentum in quantum mechanics.
I just re-edited my 2nd post there, i confused m_{j} with m_{s}, but I know that for s=1 m_{s} is -1,0,1 which combined with m_{l} =-1,0,1 gives 9 states in total including the 3 given by s=0 right?
Yes, there are nine states. (You meant ms and ml, not mj.)
But think about this. If j=2, then mj can be -2, -1, 0, 1, 2. That's five states. What are the other four in the |j mj> basis?
Would those be the case where only one spin is taken into account aka s=1/2, -1/2
which gives m_{j}= -3/2, -1/2, 1/2, 3/2
also, just to clarify, the only possible values for j are 1 and 2 right?
No.
No.
  • · Replies 0 ·
