Dimensions and dark matter
  • #36
phinds
Insights Author
2022 Award
18,217
11,237
Not necessarily. I didn't mean to imply that a massive photon's antiparticle must be distinct, just that the antiparticle's mass has to be the same as the particle's mass even if the antiparticle is distinct.
Thanks, Peter. So am I right then in the following thought: If a massive photon's antiparticle WERE distinct that would actually be an argument against massive photons, using the following reasoning. Massless photons don't interact since they are pure waves and pass through each other so we see no interactions. If photons had distinct antiparticles, given the number of photons zipping around there WOULD be interactions (annihilations) but we never see any such thing.
  • #37
41,297
18,934
There are two problems with this argument.
One is that a photon-antiphoton pair can only annihilate if there is some other particle-antiparticle pair that the photons could annihilate into. But even if the photon has mass, its mass has to be much, much, much, much smaller than the mass of any other particle, so the hypothetical massive photon-antiphoton pairs flying around have far too small an energy to produce any other particle-antiparticle pair. So they can't annihilate each other because there's no other accessible state for the pair to go into.
The other is that even massless photon pairs can "annihilate" and convert themselves into other particle-antiparticle pairs if they have enough energy. The simplest case is gamma rays producing electron-positron pairs, which AFAIK has been observed in experiments.
Likes phinds
  • #38
phinds
Insights Author
2022 Award
18,217
11,237
Thanks.
  • #39
Helios
271
62
Folks, I remarked that a ( hypothetical ) massive photon had strange consequences. Just wondering. These were not objections. I did not use this as evidence in an attempt to disprove the existence of massive photons. I don't need to show why a massive photon is not possible, unless I asserted that they are impossible. I am allowed to say that it is possible that there are no massive photons. This is also a hypothesis, I suppose. Another is allowed to say that it is possible that there are massive photons. I don't know of any compelling reason to suppose this. Who is required to prove or disprove?
I said "contradict the entirety of modern physics"
Ibex said "we'd have to add a lot of footnotes to relativity texts and rewrite a lot of particle physics texts."
  • #40
41,297
18,934
"Strange" compared to what we're used to observing, sure. But that's because all of our current evidence says photons are massless.
Your claim of "strange" is much stronger than just "different from our current evidence".
This is still much stronger than what @Ibix said. Scientists revise our best current theories all the time as we get new evidence. That doesn't mean new evidence "contradicts the entirety" of our best current theories. It can't possibly do that, since our best current theories are based on mountains of evidence we already have that confirm them.
  • #41
41,297
18,934
Basically, this amounts to "there might be massive photons, or there might not be". What's the point of saying that? It's a logical tautology.
You are hijacking someone else's thread with irrelevant quibbles. Therefore, you have been banned from further posting in this thread.
Likes weirdoguy
  • #42
Klystron
1,616
It may be the case, speculating, that we may just perceive 'shadows' or projections into lower dimensions, as in the book 'Flatland'. But this is just an educated guess.
Nice, added to the reading list.
[snip...]
I also recommend reading Edwin Abbott's (AKA 'A. Square') novella "Flatland" and to add to the OP's reading list consider "Spaceland" by Rudy Rucker.
Likes WWGD
  • #43
kimbyd
795
Is it correct that dimensions more than the three (4th being time) that we perceive can be mathematically modeled but as yet remain unobserved?
If so, is it possible that dark matter/energy are "elements" which exist in those higher dimensions, and as such remain invisible to those constrained to four?
The general picture is as follows. There are two general possibilities:
1) The extra dimensions are too small to be observed (much smaller than an atomic nucleus). While matter technically moves in those dimensions, it moves so little those motions leave no observational results (yet).
2) The extra dimensions are somewhat larger, but the particles and forces we are familiar with are confined to a 3-dimensional surface within the larger space. In such a model, all of the components of the standard model (quarks, leptons, gauge bosons) would all be confined. But gravity would not: it would necessarily leak out into the larger volume. This model has been used as an attempt to explain why gravity is so incredibly weaker than the other fundamental forces we currently know (electromagnetic and the strong and weak nuclear forces). The "large" extra dimensions would still have to be pretty small (nanometers at most, if I recall correctly).
In general such models are entirely speculative at the moment. Sadly, it's possible for these models to be true, but completely impossible to ever measure. The best we can say right now is that if we get extremely lucky and the model parameters are just right, maybe we'll be able to measure them. But in the mean time they're generally just neat mathmatical models that may have nothing to do with reality.
Likes PeroK and WWGD
  • #44
Janus
Staff Emeritus
Insights Author
1,730
How so? It wouldn't contradict Relativity. Relativity only requires that there is a invariant speed for the universe, it doesn't require light to light to travel at that speed unless light were truly massless. The fact that light is assumed to travel exactly at c is a convenience when working with Relativity, not a requirement.
Because, those Relativity texts assume light moves exactly at c when dealing with examples like the light clock and simultaneity of relativity thought experiments. Light that travels almost at c, would give pretty damn close to, but not exactly, the same results. Adding a footnote would make this clarification without having to rewrite the whole text.
Likes Ibix
  • #45
PeroK
Insights Author
2022 Award
24,035
15,729
It might be more of a nuisance for texts on classical electromagnetism.
  • #46
Theory
Yes; string theory does this. But we have no experimental evidence for any such model.
They can't remain "invisible" in our four dimensions, since we observe their effects.
Where can I submit my theory of cosmic evolution for others to give their opinions?
  • #47
Orodruin
Staff Emeritus
Insights Author
10,661
If you have original research you should submit it to any of the many leading journals in the field that you are regularly reading to keep up to date with the latest development in the field.
Likes PeroK, berkeman and weirdoguy
  • #49
PeroK
Insights Author
2022 Award
24,035
15,729
If not, there's always twitter!
  • Haha
Likes phinds
  • #50
41,297
18,934
PF is not for original research. As @Orodruin said, the correct venue for original research is submission to a peer-reviewed journal.
  • #51
41,297
18,934
The OP question has been answered. Thread closed.
Suggested for: Dimensions and dark matter
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
