I Discrepancy in Co-Moving Charges Magnetic Force?
greswd
Consider two identical charges separated by some distance. Both are moving together with the same velocity, and the velocity vectors are perpendicular to a straight line drawn between the charges.
Each charge has charge q, speed v and they are separated by a distance of r.
In the rest frame of both charges, the E-field at either charge is ##\frac{1}{4π ε_0}\frac{q}{r^2} = E_0##
Based on the Biot-Savart Law, the B-field at either charge is ##\frac{μ_0}{4π}\frac{qv}{r^2} = B_1##
##\frac{μ_0}{4π}\frac{qv}{r^2} = [v ⋅μ_0⋅ε_0] ⋅ [\frac{1}{4πε_0}\frac{q}{r^2}]##
##B_1 = \frac{v}{c^2}⋅ E_0##Let's switch to the relativistic transformation for E and B fields: ##B_y'=γ(B_y+\frac{v}{c^2}⋅E_z)##
There is no magnetic field in the rest frame of both charges, hence ##B_y = 0##
Then ##B_y'=γ⋅\frac{v}{c^2}⋅E_z##
##E_z## is the E-field in the rest frame of both charges, hence ##E_z = E_0##
We thus obtain ##B_y'=γ⋅\frac{v}{c^2}⋅E_0##
We would expect ##B_y'=B_1## , but that is clearly not the case.
What is the explanation for the discrepancy?
greswd said:
We would expect B′y=B1
Why would you expect that?
Likes greswd
Notice that for non relativistic speeds, ##\gamma \approx 1 ## and the two agree. The key point is that Biot-Savart law is an approximation, valid if we neglect corrections of order ##v^2/c^2##.
Thanks, is there a relativistic form of the Biot-Savart Law?
I thought that the laws of electromagnetism are compatible with SR.
Okay, so, before SR, we had these E and B transformations.
https://en.wikipedia.org/api/rest_v1/media/math/render/svg/dd649e1f88760a1b79f004798ad7dae9f5a9cdee
https://en.wikipedia.org/api/rest_v1/media/math/render/svg/5215bf1a0ae6503a923bef5e6c85288494e5290b
The SR transformations follow a similar idea, but with relativistic corrections.For this thread, I was inspired by Purcell's explanation of such transformations by combining electromagnetics and length contraction.
I was also inspired by these UIUC lecture notes which derive the SR E&B transformations by using parallel plate capacitors and cylindrical solenoids.
http://web.hep.uiuc.edu/home/serrede/P436/Lecture_Notes/P436_Lect_18p5.pdf
Yes, they are. But the classical laws of EM are Maxwell's equations.
Doesn't the Biot-Savart Law form part of the basis of Maxwell's equations?
For Gauss' Law for Magnetism, and also for Ampere's Law. Maxwell used Ampere's Law to as a basis for the mathematics of the Displacement current too.
Also, does the B-S Law have a relativistic form?
On a side note, what do you think of Purcell's and Errede's (UIUC) derivations?
I studied the wikipedia, and learned that Biot and Savart do not have much to do with that incorrect law for point charges:
The "Biot–Savart law for a point charge" is called that because it looks like the standard Biot-Savart law. The "Biot–Savart law for a point charge" was first derived by Oliver Heaviside in 1888. The Biot-Savart law was developed about 1820 by Biot and Savart, and that law is correct.
https://en.wikipedia.org/wiki/Biot–Savart_law
No, I think both forms of B-S Laws are correct.
I'm still thinking about the relativistic forms though.
I'm wondering why the non-relativistic forms are not co-variant although they appear to have a role in the development of the relativistic E and B transformations.
If there's a discrepancy between formulas, then some formula must be incorrect... Oh, now I see that there is an exact version and an approximate version of the Biot-Savart law for a point charge... and you were using the inexact version as far as I can see.
EDIT: No. Sorry, I saw incorrectly.
EDIT2: But did you use the correct formula for E? It seems to be a more complicated formula for E in the wikipedia.
I was looking at this:
https://en.wikipedia.org/wiki/Biot–Savart_law#Point_charge_at_constant_velocity
No.
Do you know how to derive the Biot Savart law from Maxwell's equations? Maxwell's equations are the classical laws of EM. For anything else it is important to know the derivation. Any derivation includes certain boundary conditions or assumptions, so they don't apply when those assumptions are violated.
Both Coulomb's law and the Biot Savart law can be derived as simplifications to the Lienard Wiechert potentials for point charges. The simplifications assume that the acceleration is 0 and that the speed is much lower than c.
I wouldn't call it a relativitistic form of Biot Savart, but what you are interested in is the Lienard Wiechert potentials. Those are the solution of Maxwell's equations for a point charge. Simplifying them gives Coulomb's law and Biot Savart law.
Yes, they are. But the point here is that the expression you used for the B field produced by a current assumes an infinite line of current while you are treating a single charge in motion. As Dale pointed out, one must be more careful and use the Liénard-Wiechert potentials.
Today a question regarding this topic popped into my head.
Are these formulas considered relativistically accurate?
https://wikimedia.org/api/rest_v1/media/math/render/svg/0f863b311a45bcf9cef19b6455265b2d3033dec0
https://wikimedia.org/api/rest_v1/media/math/render/svg/e591f53b6c36fbc3a2a82938dfa2e1731b6c5209
Please use the PF LaTeX feature.
here is the formula I wanted to post:
## \mathbf{B} =\frac{\mu_0 q}{4\pi}\frac{1-v^2/c^2}{(1-v^2\sin^2\theta/c^2)^{3/2}} \mathbf{v} \times \frac{\mathbf{\hat r'}}{|\mathbf r'|^2}##
from https://en.wikipedia.org/wiki/Biot–Savart_law#Point_charge_at_constant_velocity
Is it considered relativistically accurate?
Also, what is the deadline for editing a post?
Not by itself, since you have only given the formula for B. You need to include both the B and E formulas to have a set of equations that is "relativistically accurate". Even then you have to be careful how you interpret that term: it doesn't mean that B and E don't change under Lorentz transformations; it just means that the B and E given by those formulas will satisfy Maxwell's Equations after they are subjected to a Lorentz transformation (their individual values will change but the relationships between them given by Maxwell's Equations will remain valid).
4 hours after it's originally posted. Unless you have magic Mentor powers; we can edit posts forever. Is there something you need to change?
I wanted to edit #14 instead of creating a new post. But nevermind.
Both the bolded and unbolded v(s) have the same value right?
No. The bolded v is a 3-vector. The unbolded ##v## is its magnitude. These are not the same thing.
yeah, I was thinking that they should have the same magnitude.
What I understand from your statement is that after modifying the classical E and B fields to their relativistic, retarded potential forms, we can still satisfy Maxwell's displacement current equation:
##\nabla \times \mathbf{B} = \mu_0\left(\mathbf{J} + \varepsilon_0 \frac{\partial \mathbf{E}} {\partial t} \right)##
But what about J though? Should J be modified into a relativistic form?
And all of the other Maxwell equations as well.
The charge ##\rho## and current J have to be transformed properly under Lorentz transformations.
I'm only considering a single frame, no transformations between frames.
The classical Biot-Savart Law satisfies the curl equation:
##\mathbf B = \frac{\mu_0}{4\pi}\iiint_V \ \mathbf{J} \times \frac{\mathbf{\hat r'}}{|\mathbf r'|^2} dV##
##\nabla \times \mathbf{B} = \mu_0\mathbf{J}##
##\mathbf{J}=ρ\mathbf{v}##But then we consider the relativistic Biot-Savart law:
##\mathbf B = \frac{\mu_0}{4\pi}\iiint_V \ \frac{1-v^2/c^2}{(1-v^2\sin^2\theta/c^2)^{3/2}}\mathbf{J} \times \frac{\mathbf{\hat r'}}{|\mathbf r'|^2} dV##
I wonder how it satisfies the curl equation. Maybe the curl of the field remains unaffected?
The classical Biot-Savart law for a continuous current distribution in some volume.
The relativistic Biot-Savart law for a point particle. Which is not the same as a continuous current distribution in some volume. Notice that there is no integral sign in the "relativistic" expression on the Wikipedia page.
yes true. so what is the Biot-Savart law for a continuous charge distribution that is moving at relativistic speeds?
Does it have any bearing on the curl of the B field when compared to the classical Biot-Savart law?
The closest thing I can think of would be Jefimenko's equations.
J is fine, you only worry about relativity for J if you are transforming to another frame.
Imagine two fields of charge. One has a high charge density but slow speeds. One has very low charge density but high speeds, relativistic speeds.
Therefore both have the same J fields, numerically speaking.
Although the B fields of both are different, do they both have the same curl?
The B field of both are the same
Why does this factor not lead to a different B field? If the proof is complex maybe you can just post a link, that's ok.
##\frac{1-v^2/c^2}{(1-v^2\sin^2\theta/c^2)^{3/2}}##
  • #31
The easiest way to see that is to just look at the retarded potentials. In the retarded potentials A depends only on J and B depends only on A. So if J is identical then B is also identical.
Likes greswd
  • #32
Wow that's so counter-intuitive. :)) I think almost anyone looking at the problem at first glance would assume that the B-field would be affected.
Does this mean that the relativistic changes within the charge distribution somehow offset each other?
  • #33
I don't know what you mean by that. Aren't you dealing with a single frame? So what relativistic changes are you talking about in a single frame?
  • #34
The ##\frac{1-v^2/c^2}{(1-v^2\sin^2\theta/c^2)^{3/2}}## factor getting larger and larger as the speeds of the charge distribution increase.
The increase in speed is matched by a decrease in charge density, as mentioned in #28, so that J remains unchanged.
  • #35
I am not exactly sure what that factor is or where it comes from (in terms of assumptions in the derivation). If it is for a point charge then you cannot increase v without increasing J also.
  • #36
I first mentioned it in #16:
I thought you had acknowledged it in #31 as well:
A continuous charge distribution can be approximated by a 'cloud' or 'fine mist' of point charges.
I am talking about the comparison of two different scenarios, one with dense charge and slow speeds, and another with less dense charge and faster speeds.
  • #37
I was just quoting your post.
You can get a lot of incorrect intuition that way. For example, you might conclude that you should get synchrotron radiation from a DC current loop.
greswd said:
I am talking about two different scenarios, one with dense charge and slow speeds, and another with less dense charge and faster speeds.
If J is the same in the two different scenarios then B is the same in the two different scenarios.
  • #38
haha, that's interesting, why can't we get sync radiation from a current loop? Isn't the current in a loop also made of moving charged particles?
Yes, you told me that already. So I asked if this was due to the relativistic effects offsetting each other.
I asked because B being the same in both scenarios is so counter-intuitive to me.
  • #39
Because J is not a function of time for a DC current loop so there is no radiation.
Which is precisely why thinking of a continuous current distribution as a collection of charged point particles can give you faulty intuition.
Understood. Unfortunately, what you mean by "relativistic effects" here is a term from an equation for point charges, so it doesn't readily apply for continuous charge distributions.
Of course, it is possible to go from one to the other through careful integration, but it is not trivial and the proof from continuous distributions is so easy that I don't see the point in going through that exercise.
  • #40
Do you know of any webpage that shows how to go from one to the other?I found this article about synchrotron radiation: http://puhep1.princeton.edu/~kirkmcd/examples/steadycurrent.pdf
Kirk T. McDonald said:
If the steady current were a continuous DC current, all of its multipole moments would be constant, and we would expect no radiation.1 For a current consisting of electrons, it must be that the radiation is canceled by destructive interference between the radiation fields of the large number N of electrons that make up the steady current.
I sound like a broken record; is it useful to think of the relativistic effects offsetting one another just like the destructive interference between the radiation fields of a continuous steady current?
  • #41
Not for this specific problem, no. But you can get a general idea of the approach in calculus based discussions of Newton's shell theorem.
The comment about destructive interference is perfect.
I can't answer this for the reason described above.
  • #42
which reason?
  • #43
greswd said:
which reason?
Last two paragraphs of post 39
  • #44
so its because the proof is not easy? ok.
  • #45
Well, the proof which I gave is very easy, it just doesn't involve the terms you are choosing to focus on. Putting those terms in would be hard and would serve no other purpose, so I am not inclined to do it nor do I know of anyone else who was. You are certainly welcome to do it if it feels important to you.
  • #46
Yeah, no worries. You've already explained how it works conceptually, which has been enough to answer my question(s).
It is actually important to me, but since its so hard I'll save it for another day.
Thanks for all the help rendered for this thread.:thumbup::sun:
