Discrete Math irrational and rational numbers proof
3 replies · 10K views · last reply
abjf9299
Prove by contradiction. Your proof should be based only on properties of the integers, simple algebra, and the definition of rational and irrational.
If a and b are rational numbers, b does not equal 0, and r is an irrational number, then a+br is irrational.
rational numbers are equal to the ratio of two other numbers
I wrote a proof but am not sure it is correct. Please tell me what I did wrong and show me the way to do it right if this is not correct. My teacher indicated that we need to make use of the fact that b does not equal 0 (from a+br). Did I do that sufficiently as well?:
Proof: Suppose not. That is suppose that there exists rational numbers a and b, b does not equal zero, and irrational number r such that a+br is rational [We must deduce a contradiction].
By definition of rational, a = c/d, b= e/f , a+br = g/h for some integers c,d,e,f,g,and h with h,f,d, and b not equal to 0.
By substitution, a+b(r) = c/d +(r)( e/f) = g/h.
Solving for r gives: r = (fgd-chf) / (ehd)
Now fgd and chf are integers (being products of integers) and ehd does not equal 0 (by zero product property). Thus by definition of rational, r is rational which contradicts the supposition that r is irrational [ Hence the supposition is false and the statement is true].
Looks pretty solid. A few minor things I found:
1) You want to state when you're defining b that e is also not equal to 0.
2) You probably want to list your steps for solving for r, so your teacher doesn't need to go do extra work and check if it's right.
Thanks for the help! I'll correct those things ASAP before handing it in...
Since you have already answered the question, I don't mind pointing out some shortcuts. Let c = a + br, and assume a, b and c are rational, and that b =/= 0. Then we can solve for r: r = (c-a)/b (legal because b is not zero). The numerator c-a is rational and the denominator b is rational, so their ratio is rational. This contradicts the assumption that r is irrational. Thus, c must also be irrational.
RGV
