Discrete mathematics and its application 2.4 problem 26
14 replies · 4K views
GoGoDancer12
Find a formula for when m [tex]\sum[/tex] k=0 the flooring function of[k1/3 ] ,m is a positive integer.
n[tex]\prod[/tex] j=m aj
the flooring function of[k1/3] = K
the summation of K is [tex]\frac{m(m+1)}{2}[/tex]
There's a table of useful summation formulas in the Discrete Mathematics and Its Application sixth edition textbook pg.157 and that's where I got the summation formula for K. Just plug in m in the formula for the summation of K.
on Phys.org
omit the second part
2. Homework Equations
nLaTeX Code: \\prod j=m aj
...not part of the problem
I have to find the summation formula for floor(K1/3):; and m is the on top of the summation symbol.
Start by expanding the summation:
floor(1) + floor(21/3) + floor(31/3) + ... + floor(m1/3).
Use enough terms so that you can find out how many of the terms will be equal to 1, to 2, to 3, and so on. That's what I would start with.
I'd be willing to offer some help but I can't quite read you equations! Could you try and format them a bit better?
GogoDancer12 wants to find a closed for expression for
[tex]\sum_{k = 0}^m \lfloor k^{1/3}\rfloor[/tex]
The [itex]\lfloor[/itex] and [itex]\rfloor[/itex] symbols are for the "floor" function, the greatest integer less than or equal to the specified argument.
Again, try expanding as I suggested in post #6. You're going to get a bunch of terms that are 1, a bunch that are 2, and so forth. See if you can figure a way to count how many 1s, 2s, and so forth.
after expanding the summation I got this :
1+1+1+1+1+1+m
after expanding the summation some more I got this:
1+1+1+1+1+1+1+2+2+2+2+2+2+2+2+...+m
and I'm still lost.
How many 1s are there? How many 2s? 3s? Can you find any pattern? At what value of k do the 1s turn to 2s? Do the 2s turn to 3s? Are you sure the last number will be m?
Here's a tip: look at the inverse function of [itex]x^{1/3}[/itex], which is [itex]x^{3}[/itex]. Then you'll see this that:
[tex]\left\lfloor k^{1/3}\right\rfloor=1 \Rightarrow k \in \left[1,2^{3}\left[=\left[1,8\left[[/tex]
[tex]\left\lfloor k^{1/3}\right\rfloor=2 \Rightarrow k \in \left[2^{3},3^{3}\left[=\left[8,27\left[[/tex]
and so on...
From this you should be able to count the number of 1,2,etc.
