Distance a particle travels if launched tangentially into space
  • Thread starter Thread starter aheizler
    Particle Space
1 reply · 2K views
aheizler
A non-rotating spherical planet has mass M and radius R. A particle is fired off from the surface with a speed equal to 3/4 the escape speed. Calculate the farthest
distance it reaches (measured from the center of the planet) if it is fired off tangentially.
GPE = G*M*m*((1/R) - (1/d))
KE = ½*m*Ve²
I did this problem correctly when the problem stated that the particle is fired off radially (d=R*(16/7)), but I don't know what changes when the particle is fired tangentially.
When fired radially you assume the maximum distance is when the velocity goes to 0. But when fired tangentially (or throwing a ball in the air at an angle), the maximum height doesn't have 0 total velocity (so KE_final is not 0). The maximum height will have 0 radial velocity, but can still have tangential velocity.
So you will need to use conservation of angular momentum to help solve this.
