Distance between earth and moon increasing
The distance between the Earth and the Moon is increasing due to tidal interactions, where the Moon causes a tidal bulge on Earth. As the Earth rotates, it attempts to drag this bulge, but the Moon's gravitational pull keeps it aligned, resulting in a "tug of war" that slows Earth's rotation. This loss of angular momentum is transferred to the Moon, causing it to move into a higher orbit. Eventually, the Moon will reach a stable orbit, but this process will take an extensive amount of time. Ultimately, the Moon is expected to drift further away until it meets the Sun at the end of its life cycle.
mubashirmansoor
I learned that the distance betwee the Moon and the Earth is increasing but I couldn't find the reason for it, Is it because of the Earth's orbit? I mean that when the distance is minimum , causes the moon to move towards the sun ( Newtonian laws ) and even when the distance becomes maximum the Earth won't be able to completely recover the effect which had made the distance greater... ? Thankyou for your answers
Astronomy news on Phys.org
Its due to tidal interaction between the Earth and Moon.
The moon causes a tidal bulge in the Earth.
The Earth tries to drag this bulge along with its rotatation, while the Moon tries to keep the bulge aligned with itself.
The result of this "tug o war" is that the Earth's rotation slows and the resultant loss of angular momentum is transferred to the Moon, lifting the Moon into a higher orbit.
I watched a video about the Moon's fate. Eventually it will reach orbit stability, I believe that's what they said. When that happens our planet will wobble feverishly. Then the moon will eventually meet the Sun when it's near its own end of life.
Agreed theoretically, but it will take an astounding amount of time.
Thankyou for ur answers I wanted to know if I have understood the task correctly or not:)
the direction of motion of these two heavenly
bodies are totally opposite. This means that the tides on Earth will have a
direction opposite to the earth’s rotation and this causes the Earth to slow
down and in other words it’s angular momentum will decrease where P = m.v
so due to the decrease in v the ‘P’ will decrease or in other words the effect of
gravitons decreases which will cause the moon to feel comfortable to escape
from the gravity and this causes the moon to take a distance form the earth
BUT as we all know the space-time curve of Earth is quite larger than the
moon’s so we can expect a certain position of moon where Earth won’t be
effected by it and the moon will be still inside the curve & that is the point
where the moon would get a stable situation
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
